Hey all. I have an 09 Charger and I am running into a new problem. I have 2 antennas installed with a the Laird Trunk Lip mount located symmetrically in the center of the trunk (in line with the 2 parallel defroster lines on the window). They have been doing fine (the cables run from that point under the trunk to the large space on the inside of the trunk roof, and follow that on the inside to where the wiring harness for the 3rd brake light passes through into the main body of the trunk). However they have been there about a year and the cable as it passes over the rubber molding on its trip from the antenna base to the area where the cable goes into the inside part of the lid, has begun to depress the molding causing my trunk to leak in the 2 areas where the cables pass over it. When I was first measuring it seemed these mounts wouldnt be able to sqweeze on the driver and passenger side of my trunk, which is why the were installed on inner lip by the window. However I recently saw a charger placed exactly like so with the same mounts I do and doesnt seem to be a problem. I would assume if I relocate them I would have the same problem as I do now just in a different location due to the molding (not to mention a nasty mark from where the two antennas are placed now). If anyone has these antenna mounts on a charger Id like to know how they look underneath and if you put fastners on etc. Ill snap some pics and send em up here as soon as I can so everyone can get a better idea.
Thanks!
LinkBack URL
About LinkBacks
Impala SS
Summer Toy
Dodge Dakota
