Results 1 to 7 of 7
  1. #1
    Author of This Thread
    CHIEFOPS is offline
    Joined January 2011
    NYC
    2011 charger pursuit police power distribution center
    ok, wasn't sure where to post this.
    I'm having trouble locating the police power distribution center to replace a fuse. The 2006-2010 upfitting guide states it's "located below the glove box and to the left of the right kick panel", however the 2011 upfitting guide doesn't list where it's located, leaving me to believe it's in the same location. Only problem is, it's not there. Is it tucked further up next to the glove compartment instead of below it?
  2. #2
    Premium Verified Member
    Manufacturer
    Professional Upfitter
    EVModules is offline
    Joined May 2010
    Deer Park, WA
    Look towards the firewall.
    Sean M. Barr
    EVModules
  3. #3
    CHIEFOPS is offline
    Joined January 2011
    NYC
    Sean, in the 2006-2010 upfitting manual photo, the PPDC is mounted low enough that you can easily see the front lower corner of the door opening, not so on my 2011. I just double checked- removed the door sill trim, floor mat and peeled back the carpet, though this time I didn't drop the footwell sound insulation cover. The PPDC is definitely not "below the glove box", either on the right kick panel or on the firewall. I do see a bundled wire harness that goes up the forward/right corner of the firewall to somewhere next to the glove compt or on the firewall in front of the glove compt. It seems I'm going to have to remove the entire glove compt to access it if that's where it is. Is that correct?
  4. #4
    code4services.com is offline
    Joined November 2010
    Pelican Rapids, MN
    Those circuits are now located in the underhood PDC. (pages 47-48 upfitter guide)
    cavities: (all 20 amp)
    1
    2
    21
    22
    23
    24
  5. #5
    CHIEFOPS is offline
    Joined January 2011
    NYC
    Bingo! Thanks! Another deficiency of the Dodge literature for not highlighting that particular change.
  6. #6
    Manufacturer
    Joined May 2010
    Deer Park, WA
    I can testify to that with the 2008 & 2010 Chargers when there were significant changes. Glad Code4Services came around.
    Sean M. Barr
    EVModules
  7. #7
    CHIEFOPS is offline
    Joined January 2011
    NYC
    Quote Originally Posted by code4services.com View Post
    1
    2
    21
    22
    23
    24
    That should read 7, 8 not 1, 2 but thanks for catching it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
