Results 1 to 9 of 9
  1. #1
    Author of This Thread
    Hobbyist
    Collector
    RVGirlAlice is offline
    Joined May 2011
    Broken Arrow, OK
    Can a Cobra 29 power a 100W Speaker?
    i was curious if a cobra 29 can power a 100W Speaker because in security you are not allowed sirens in oklahoma. whelen makes a air horn/pa but can i do it with a cobra 29???
  2. #2
    Senior Member
    Volunteer Fire Fighter
    Dealer
    Hobbyist
    FireGuru is offline
    Joined May 2011
    CENTRAL OHIO
    It would for a little while. Those amp in the radios are only 5-10 watts output, and could blow your radios output amp. RadioShack sells the speakers to mount behind the grill/under hood for that radio as well as eBay and other radio oriented sited like Copper Electronics, Inc..
    Hope that helps!!
    Good to see you back on here, hadn't seen ya' for a while.
  3. #3
    Guru
    Security
    Emergency Management
    Communications
    Jarred J. is offline
    Joined May 2010
    i would say NO.
    siren speaker is 8 ohms right?
    the lil speaker that is supposed to go behind a cb is like 4 ohms. if it did work youd be better off yelling out the window.
    Well, what's this year got in store?
    EMA Radio ID #550
    City Park Guard Radio ID #Truck 100
    Callsign KK4BBG
  4. #4
    Junior Member
    Transportation
    Fire/EMT
    Hobbyist
    slash9dotnet is offline
    Joined February 2012
    Conneaut, Ohio
    Quote Originally Posted by Jarred J. View Post
    i would say NO.
    Hahaha! Absolutely correct.
    The speaker would be way underpowered and like the others said, would be the ultimate death of your radio.
  5. #5
    Senior Member
    Clarence H is offline
    Joined May 2010
    USA Twin Cities Minnesota
    Siren Speakers
    Most siren speakers are 11 Ohms.
    Clarence
  6. #6
    Junior Member
    Transportation
    Fire/EMT
    Hobbyist
    Conneaut, Ohio
    Quote Originally Posted by Clarence H View Post
    Clarence
    Yes, that is true and I stand corrected, as well. I had just meant that he'd be better off yelling out the window trying to power a 100w speaker like that.
  7. #7
  8. #8
    First Responder
    JazzDad is offline
    Joined August 2011
    South Central Texas
    Re: Item 3 link.
    Wow! A thousand watts?
  9. #9
    Hobbyist
    Collector
    Joined May 2011
    Broken Arrow, OK
    i thought as much, but would saved some cash if could of
Posting Permissions
  • You may not post replies
  • You may not edit your posts
