Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By crescentstar69
  • 2 Post By Blade Runner
Thread: Dumb question - anyone else color/darken their radar antenna?
  1. #1
    Author of This Thread
    Communications
    Professional Upfitter
    Emergency Management
    STT Installer is offline
    Joined May 2010
    Idaho
    Was over at another agency last weekend that uses a number of odd ball vehicles for traffic enforcement (which in itself is a can of worms I'd rather not get in to)... Anyways, noticed that they had a number of MPH Python radar units that they appear to have used Sharpie/black permanent marker on the white radome of the K band radar antennas to reduce their obvious appearance...
    I can't find anything anywhere that says yay or nay to this approach other than painting fiberglass antennas on Batlabs specifically using a microwave oven on a test section of paint to see if it heats up (choosing paint that doesn't contain metals that would reflect RF/skew VSWR)...
    I remember years back one of the manufacturers, maybe Kustom, that had a 2"x2" square black ABS Ka radar antenna that was incredibly stealthy... That same agency I think might have used panty hose over their radar antennas too...
    Anyways, anybody ever run in to this? I'm certain there are plenty of folks on here in LE that can comment, a couple of which that might be certified in speed detection instruction?
  2. #2
    Veteran
    Vintage Collector
    Retired
    crescentstar69 is offline
    Joined July 2010
    S.W. Ohio USA
    I would make a quick call to the manufacturer. I have called MPH in Owensboro, KY before and received great customer service. Personally, I wouldn't fool with it, and I don't see any real benefit.
    50theman likes this.
  3. #3
    Blade Runner is offline
    Joined May 2010
    Houston/Katy, Texas
    Sounds like a good reason for an attorney to get any tickets written by said unit tossed out......
    calebsheltonmed23 and jcpse like this.
    S. "Mater" Jackson,
    Vol. Firefighter/Chauffeur
    http://sincemylastcigarette.com/bann...USD_5_dark.png
  4. #4
    Veteran
    Collector
    Communications
    SireLite is offline
    Joined May 2010
    Conwy, Wales, GB
    Quote Originally Posted by Blade Runner View Post
    If that was the case. having the unit mounted inside the vehicle would be a no no. You forget you also have just under 10mm of glass in front of the radar as well. which could bounce the radar waves back into the vehicle. (maybe a hazard to health?)
    I don't think colouring in or placing some tights over the radar would effect its performance. Maybe its time someone did a comparison of the unit mounted inside and outside the vehicle.
    Jim - SireLite Thinking outside the box.
  5. #5
    Senior Member
    Law Enforcement
    PJD642 is online now
    Joined May 2010
    32 miles east of Cleveland
    My radar unit's antenna practically GLOWED it was soo bright white. So I did just what the OP mentioned - took a black sharpie and colored the dome. From 5 feet away, it looked factory, and really made it less obvious. I personally didn't notice any difference in range or sensitivity. YMMV.
    Moot point now, though, I just turned it back in. I never did a lot of traffic enforcement anyway, and mostly used it for PC to stop. If I had a highway system running through the Parks, it'd be a different story, but any interdiction stops I make nowadays have nothing to do with speeding.
    Twitter.com/K9Carly
  6. #6
    Junior Member
    Law Enforcement
    jt1562000 is offline
    Joined March 2012
    Idaho
    My radar is still white.....but we have one car here that they used a black sharpie on the domes. Still works fine and is a lot harder to notice. I wouldn't do it to mine, just because I really don't want to have to explain it on the stand some day.
  7. #7
    Law Enforcement
    kenton1979 is online now
    Joined September 2010
    Indiana
    One guy I worked with used panty hose on his, it worked fine and he has been to court often. Easy on and easy off too if it doesnt check okay.
  8. #8
    Veteran
    Fire/EMT
    Communications
    Corrections Officer
    calebsheltonmed23 is offline
    Joined January 2011
    Laclede County, MO
    Quote Originally Posted by SireLite View Post
    There was a study a while back on the effects of testicular cancer on (male) officers when they would put the radar in between their legs aimed at the crotch. I can't for the life of me remember what it said because I was tired, but maybe someone else knows?? lol
  9. #9
    Law Enforcement
    C2Installs is offline
    Joined May 2010
    Tennessee
    A Sharpie should be fine. I wouldn't paint it, and I wouldn't cover it, but a sharpie to the lens would probably be ok. Either way a simple call to the manufacturer should net an answer. A vague, non-committal answer if I had to guess, but an answer. I've seen radars mounted in so many ways, behind grilles, inside lightbars, behind glass, that I doubt a sharpie dye job will hurt. Worst case would be reduced range or how quick it can read the return signal, both of which would be in the motorist's favor. If it still checks accurate with the tuning forks, I doubt any attorney will have significant luck tearing it down in court. Besides, how many times are attorneys really challenging radars now days? And these challenges are usually answered by showing a calibration certificate, a maintenance log, a record of daily testing, and the officers testimony that the unit was working properly to the best of their knowledge. In court, an attorney would either have to be so radar savvy that he/she would know the radar antenna had been colored, or would have to ask under oath if the radar had been modified in any way. This is a different question/answer than, "was the radar unit working properly, to the best of your knowledge?" Further, radar readings, in and of themselves, are not a means to convict for speeding. The officer has to be able to testify that his observations of the vehicle were such that he independently concluded it was speeding, with the radar being used to affirm his independent judgement, usually within five MPH.
  10. #10
    Law Enforcement
    NC lawdog is offline
    North Carolina
    Quote Originally Posted by kenton1979 View Post
    Black stockings work great. Never had any problem doing a tuning fork test with it on an it makes the whole antenna black for a more stelth look. I'll try to get a pic later today.
    Beali Pasifici. Relentless pursuit!
    Speak softly and carry a big stick...to stir the pot with!
  11. #11
    AggiePhil is offline
    Joined July 2010
    Southwest
    For the past few years, Stalker antennas have come with black covers.
  12. #12
    Junior Member
    Communications
    Law Enforcement
    cswroe is offline
    Joined April 2012
    Northwest Indiana
    Re: Dumb question - anyone else color/darken their radar antenna?
    The Bee III's we have been getting have had black antennas as well.
    Would the spray window tint be an option? Works great on lenses in an unmarked squad too.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
