Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By smsales
Thread: I have a bunch of wire that needs to be stripped. easy way to do it????
  1. #1
    Author of This Thread
    Fire/EMT
    Professional Upfitter
    Dealer
    smsales is offline
    Joined May 2010
    West Michigan
    i am looking for something easy to strip a bunch of wire that i have laying around. Im looking for a Manual Wire Stripping Machine for Recycling. Anyone have an ideas?
    thanks
    Scott VanderVeen
    SM Sales and Installs
    1-616-886-2868
    West Michigan's Pimp Pod and Carson Distributor
    salesandinstalls@gmail.com
    Like us on Facebook! http://www.facebook.com/pages/SM-Sal...386356?sk=wall
  2. #2
    LED
    LED is offline
    Joined May 2010
    New England, MA
  3. #3
    Veteran
    Fire/Paramedic
    Communications
    Respondcode3 is online now
    Joined May 2010
    Northen Il USA
    Do it Ghetto style.. 55 gal Drum and gasoline!
  4. #4
    Fire/EMT
    Dealer
    smsales is offline
    Joined May 2010
    West Michigan
    Quote Originally Posted by LED View Post
    works well for braided wire too? i saw that one, but hate buying stuff online before seeing it.
    Scott VanderVeen
    1-616-886-2868
  5. #5
    Support Services is offline
    Joined May 2010
    Lebanon PA
    Look on youtube
    Check out youtube they have several vidio's of homemade wire stripers.
    Any Mission
    Any Time
    Any Where
    Support Services
  6. #6
    Fire/EMT
    Dealer
    smsales is offline
    Joined May 2010
    West Michigan
    Quote Originally Posted by Support Services View Post
    i tried the homemade stripper. didnt work very well.
    RBRONKEMA GHTFD likes this.
    Scott VanderVeen
    1-616-886-2868
  7. #7
    911
    Guru
    Dealer
    Police/EMS
    911 is online now
    Joined May 2010
    New York City
    around here, they pay well with the insul on, no need for me to do any work !!
    Authorized Dealer for BlackBox, Kenwood, Vertex Standard,HYT, Motorola Parts & Accessories . WE Buy Radios , Got a Radio To Sell? Contact US for a EZ Quote Anytime !!
    Mobile # (718)490-7446
    Monday thru Friday 9:00 AM- 5:00 PM EST
  8. #8
    Veteran
    NPS Ranger is online now
    Joined May 2010
    Penn's Woods
    Quote Originally Posted by Respondcode3 View Post
    Beat me to it! If it works for copper thieves, it'll work for you too.
  9. #9
    Manufacturer
    STT Installer is offline
    Joined May 2010
    Idaho
    After all of the thefts around here, they passed local ordinances in this part of the state making it a crime to accept wiring for recycling that has been obviously burned. We also require photo ID to be logged at the recycler for anyone turning in any kind of wiring, plumbing or air conditioner equipment.
  10. #10
    Veteran
    ERIC6913 is offline
    Joined May 2010
    California
    They call me the copper master and there is one tool that has made me thousands. thewirezipper.com
  11. #11
    Senior Member
    Ipuvaepe is offline
    Joined June 2011
    Southeast Pennsylvania
    desk/table mounted vice (or otherwise secured to the ground) and a utility knife blade. Fix the blade vertically at a 45° angle or so and adjust the vice so the distance between the blade and the other end of the vice is exactly the width of the wire plus the thickness of the insulation (or a little more than that for good measure), and then just pull the wire through and when you're done peel the insulation off. I wouldn't do it with more than 100ft or so, as it'll be less time and energy efficient than building/buying a full on mechanical wire stripper.
    Oh and if it gets stuck or too hard to pull, don't just keep pulling or the blade might snap and hit you in the eye or something, cheap shit.
    Any material protected by copyright in this post is covered by Fair Use, unless otherwise noted.
    This post is provided for informational purposes only and does not constitute legal advice or professional opinion on specific facts. Information provided in this post may not remain current
    or accurate, so recipients should use this post only as a starting point for their own independent research and analysis.
  12. #12
    Veteran
    ERIC6913 is offline
    Joined May 2010
    California
    Quote Originally Posted by Ipuvaepe View Post
    way too dangerous buddy, check out that website in my previous post
  13. #13
    Fire/EMT
    Dealer
    smsales is offline
    Joined May 2010
    West Michigan
    i just order this thing. i have 14 days to return it if i dont like it. well give it a shot and see what happens. thats just it, you do installs and have cut off, you can really use it for anything, so im going to get some money back out of it. ill let ya know after i use it.
    thanks for the info...if i may ask, how much for that stripper you posted?
    Scott VanderVeen
    1-616-886-2868
  14. #14
    GPC
    Transportation
    GPC is offline
    Joined October 2010
    North Carolina
    Quote Originally Posted by NPS Ranger View Post
    If anyone decides to go this route just expect a visit from your friendly local deputy.
  15. #15
    Veteran
    ERIC6913 is offline
    Joined May 2010
    California
    Quote Originally Posted by smsales View Post
    I am a union electrician and i wore through the nylon blocks quickly. i had to order the aluminum inserts after a couple thousand feet that i stripped. i have literally stripped miles of smaller and medium wire with that tool. its a little tricky sometimes and i used some silicone spray in the inserts to help lubricate the wire as it enters the block. WELL WORTH YOUR MONEY IF YOU'RE SERIOUS ABOUT STRIPPING WIRE.
  16. #16
    Junior Member
    Transportation
    Fire/EMT
    Hobbyist
    slash9dotnet is offline
    Joined February 2012
    Conneaut, Ohio
    Hahahahaha! I could only imagine.
  17. #17
    Veteran
    ERIC6913 is offline
    Joined May 2010
    California
    looks like that one is for large wire only. the one i recommended is for small to medium size wire. 14 guage to 1/0 guage solid or stranded.
  18. #18
    Fire/EMT
    Dealer
    smsales is offline
    Joined May 2010
    West Michigan
    http://www.amazon.com/gp/product/B00...D0MQW3VMB6SZYV
    This unit works really well. the worst part is adjusting for the right size. that is if you have a mixed amount of size. i did all 150 lbs in about 3 hours.
    Scott VanderVeen
    1-616-886-2868
Posting Permissions
  • You may not post replies
  • You may not edit your posts
