Results 1 to 12 of 12
Thread: Mag Light Holder
October 11th, 2011, 09:51 AM #1Author of This ThreadMember
- Joined September 2011
Orlando, FL60 PostsMag Light Holder
I've seen a few installs on this board with a plastic sleeve/collar for a mag light to drop into, normally mounted on the side of a console, dash or partition. Where can I get one of these? Example below
October 11th, 2011, 10:24 AM #2MemberLaw Enforcement
- Joined May 2010
Quincy, Illinois247 PostsThat's not a Maglite. That would be a Streamlight.
October 11th, 2011, 10:26 AM #3Author of This ThreadMember
Orlando, FL60 Posts
October 11th, 2011, 10:43 AM #4
http://www.amazon.com/gp/aw/d/B00002...dir_mdp_mobile
That's the only thing they make, to my knowledge. They work really well. You can get them at most ace hardware stores."Elightbars... where wannabes come to bicker with professionals, thru the safety of the internet"- Maranos
October 11th, 2011, 08:33 PM #5
October 12th, 2011, 01:47 AM #6
All that I have seen that are mounted like that (including my own) are mounted using the charging cradle.
October 13th, 2011, 08:17 AM #7Member
- Joined June 2010
Kane County, IL228 PostsStreamlight - SL-20X
June 16th, 2012, 12:39 AM #8MemberVolunteer Fire FighterHobbyist
- Joined June 2012
New York- Long Island172 Posts
June 16th, 2012, 01:05 AM #9
My dad has a streamlight that looks and mounts like the one pictured. Not sure what model. And its the charging cradle for it.
June 16th, 2012, 08:52 AM #10
The light in the photos, as stated is a Streamlight flashlight. Its holder actually is the charging base, also as stated.
If you would like one for a Mag-Light, look for a used Mag Charger charger. The hold it very well.
I also think there is one being sold here on the board. You can also remove the charger from its base if you need to make room, and do not want the bulk of the charger.
Here are some pics, the MagCharger is the same size as a 3-Cell D flash light, so it will fit any other size D cells. The bottom of the charger is a base that mounts to your surface, and then you snap in the charger. You can see the base in the pics.
June 16th, 2012, 04:19 PM #11
A piece of schedule 80 PVC conduit from the local hardware/hjome improvement store would work for a maglite. That's what I have in my work truck and it works well.
"LA Clear, KMG941"
As a great man once said... "Heeeeeeeeeey"
June 16th, 2012, 05:39 PM #12
I like the PVC idea. I've used the Mag Lite clip system, and have broken many clips. The PVC would be unbreakable.
LinkBack URL
About LinkBacks
Impala SS
My 2004 Chevrolet Z71 Suburban
2008 Grand Cherokee
Jason's Ride
Beacon Wall
dmathieu - Collector Showcase
Federal Signal Valor Lightbars 48"...
June 17th, 2013, 05:47 PM in For Sale or Trade: Premium Listings
