Results 1 to 14 of 14
  1. #1
    Author of This Thread
    massfirefighter is offline
    Joined June 2010
    Massachusetts
    Mobile transceiver microphone extension.
    Does anyone know if it possible to extend a radio's microphone with a Cat5 cable? I figured I could crimp an rj45 on the cab end and add a jack in the rear of the
    truck.
    A local chief wants to use one radio that is mounted in the cab for fireground ops by adding an extra mic and speaker in the back of his suv. He wants to be able to unplug the mic inside, plug in the extension cable, and bring the mic out back. He has a Kenwood TK880 so I don't believe there are any options for dual heads.
  2. #2
    Senior Member
    EMT
    Volunteer Fire/EMT
    Grotonems5 is offline
    Joined June 2010
    Groton, Vermont
    Quote Originally Posted by massfirefighter View Post
    truck.
    OPC-440 Icom, Kenwood, Mic Extension Cable 6 ft | eBay
    not sure if they offer these in longer lengths or not...
  3. #3
    Veteran
    Fire/Paramedic
    Communications
    Professional Upfitter
    Respondcode3 is offline
    Joined May 2010
    Northen Il USA
    It may be easier to just buy antother radio and mount it in the back.
  4. #4
    Joined June 2010
    Massachusetts
    Quote Originally Posted by Grotonems5 View Post
    I have shielded Cat5 cable, and RJ45 jacks and thats exactly what he is selling....perfect and free materials.
  5. #5
    Joined June 2010
    Massachusetts
    Quote Originally Posted by Respondcode3 View Post
    He's way too cheap for that. He doesn't even want to buy a second mic.
  6. #6
    Senior Member
    Volunteer Fire Fighter
    First Responder
    Communications
    FFParker is offline
    Joined July 2010
    Beech Island, SC
    I did it with both my radios using cat5 cable haven't had a problem. I have only done it with one mic im guessing if you use a splitter and ensure you obviously use only one mic at a time it should work. if you had a moto you could always run it off the acc. port in the rear of the radio...
    Amateur Radio operator, N4PKR
    Volunteer Firefighter/First responder
    BIFD Unit# 817/ JFD Unit# 919
    Firefigher II
    PAYPAL-Parkerbs@hotmail.com
  7. #7
    Senior Member
    EMT
    Volunteer Fire/EMT
    Joined June 2010
    Groton, Vermont
    Then the answer to your question is yes! If you have the tools and skills to do it, it is possible
  8. #8
    911
    Guru
    Dealer
    Police/EMS
    911 is online now
    Joined May 2010
    New York City
    my ems supervisor tahoe has a few radios with mic extensions.............. and we made them the same way.........
    just seems stupid that he is going to unplug the mic and bring it to the back............ he should spend the $100 on a used radio
    www.911radiosupply.com
    OFFICE # (718)305-1998 ext 44
    Monday thru Friday 9:00 AM- 5:00 PM EST
  9. #9
    Suspended
    Fire Fighter
    EMT
    108FP1 is offline
    Joined September 2011
    Pittsburgh PA
    Someone must be a hardcore penny-pincher if they are going to swap a mic around all the time. Talk him into 2 mics, then use a splitter and some shielded CAT5 cable.
  10. #10
    Joined June 2010
    Massachusetts
    Quote Originally Posted by 108FP1 View Post
    He is pretty cheap. I think the install will take longer than any amount of time he will be using the rear mic since fires in his area are few and far between.
  11. #11
    Joined June 2010
    Massachusetts
    Blk Coil Cord Handheld Speaker Mic for Kenwood TK-868G | eBay
    Has anyone seen these? This way I wouldn't have to add a speaker in the back.
  12. #12
    911
    Guru
    Dealer
    Police/EMS
    911 is online now
    Joined May 2010
    New York City
    you still need a speaker, its just a microphone , dont believe everything you read , look where its coming from
  13. #13
    Senior Member
    wkr518 is offline
    Joined May 2010
    42.791127, -73.679758
    I second the suggestion of just adding a 2nd radio in the back of the SUV.Having 2 UHF antennas is more forgiving than VHF,lowband antennas.Unplugging and plugging a mic is certainly to wear out over time.
    Good luck with Fire Chief Frugal
  14. #14
    Senior Member
    wkr518 is offline
    Joined May 2010
    Quote Originally Posted by 911 View Post
    Hong Kong Phuey?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
