Results 1 to 24 of 24
  1. #1
    Author of This Thread
    vff0312 is online now
    Joined December 2011
    texas
    Running antenna wire
    I am installing a tk-7180, which is a LOT more work than I was hoping. I installed the antenna and I'm currently in the process of running the antenna wire (will finish that tomorrow). The antenna wire will run along side the power wire for my dual talons for 3 or so feet. Will there be any interference when I have the talons running?
  2. #2
    Veteran
    Fire/Paramedic
    Communications
    Professional Upfitter
    Respondcode3 is online now
    Joined May 2010
    Northen Il USA
    Doubtful.
  3. #3
    ryanm is offline
    Joined May 2010
    Arkansas
    Probably be fine unless you run it near some strobe cables or something similar.
  4. #4
    texas
    Quote Originally Posted by ryanm View Post
    I don't use strobes. Only wires it will be remotely close to are its power wires, antenna wire, and the seat belt wire.
  5. #5
    Newbie
    kb4mdz is offline
    Joined August 2010
    Cary, NC
    I would say not, if, and make that IF, you have good quality coax - plenty of shielding braid. And a 7180 tops out at 50 Watts; it's not a high power radio like a 790H series might be; (100 Watts). But... if you can avoid running them together, try to do so. And if you do experience problems with your Talons, maybe a couple ferrite beads on those power wires would be a quick experiment before you have to pull the coax back & try to run it a different direction.
    Good Luck!
  6. #6
    Senior Member
    Volunteer Fire/EMT
    theroofable is offline
    Joined May 2010
    New Jersey
    ive only ever run into problems with the high power 790s on ambulances. And those problems were minimal. youll be fine.
  7. #7
    texas
    Quote Originally Posted by kb4mdz View Post
    Good Luck!
    Sadly there is no other way to route the cable, if there was I would surely have taken it.
  8. #8
    texas
    I have one more question regarding the antenna cable. I am sure this has happened to everyone while installing a mobile radio, I have 5 feet of extra cable. Can I coil it up (zip tied, loomed, the works) in the console by the radio?
  9. #9
    Guru
    Security
    Emergency Management
    Communications
    Jarred J. is offline
    Joined May 2010
    coiling up extra coax can turn it into a balun.
    use as few turns as neccesary.
    Well, what's this year got in store?
    EMA Radio ID #550
    City Park Guard Radio ID #Truck 100
    Callsign KK4BBG
  10. #10
    texas
    Quote Originally Posted by Jarred J. View Post
    What would you suggest I do?
  11. #11
    Veteran
    Fire/Paramedic
    Communications
    Joined May 2010
    Northen Il USA
    leave enough slack to remove the radio for service cut the rest off and replace the connector
  12. #12
    texas
    I don't have the crimper or an extra connector. Can I leave it as it is for now (coiled) and in a week or two go to the radio shop and have it cut?
  13. #13
    Guru
    Security
    Communications
    Joined May 2010
    nope.
    leave it loose for now. then get it fixed.
    EMA Radio ID #550
    Callsign KK4BBG
  14. #14
    texas
    nope.
    Are you saying nope to me leaving it coiled until I can get it fixed?
  15. #15
    Guru
    Security
    Communications
    Joined May 2010
    yes DO NOT leave it coiled.
    unless you want to buy a new radio
    EMA Radio ID #550
    Callsign KK4BBG
  16. #16
    texas
    What will it do to the radio
  17. #17
    texas
    I am going to the local radio store for a crimper and a connector. so there are no problems with cutting the cable?
  18. #18
    Guru
    Security
    Communications
    Joined May 2010
    why would their be? it wasnt manufactured at the length you bout it at
    EMA Radio ID #550
    Callsign KK4BBG
  19. #19
    texas
    I just read something about lengths and wave lengths. How do I strip the cable to put the new connector on? Also, to cut it, I just cut it? Nothing special?
  20. #20
    Veteran
    Fire/Paramedic
    Communications
    Joined May 2010
    Northen Il USA
    IF you dont know leave it to a professional . Its not worth blowing up a radio
  21. #21
    texas
    Quote Originally Posted by Respondcode3 View Post
    With all respect, I don't see how me putting on a connector can fry my radio
  22. #22
    Communications
    EMT
    Steve0625 is offline
    Joined June 2010
    Northville NY
    Quote Originally Posted by vff0312 View Post
    If you don't properly install the connector on the coax, you can fry the radio in several different ways: short to ground, no connection at all, or no ground at all. The mini UHF's and the BNC's are not as easy as the old PL-259's. (Just dated myself, didn't I? )
    Dispatcher II - Rochester/Monroe County (NY) Emergency Communications (E-9-1-1) March 1976 to October 2003 - Retired and loving it!
    Northampton Ambulance Service
  23. #23
    texas
    I appreciate all the replies. I ended up cutting the wire and putting a new connector on it. Thanks again.
  24. #24
    Senior Member
    Volunteer Fire/EMT
    Joined May 2010
    New Jersey
    Quote Originally Posted by Steve0625 View Post
    The 7180 should use the pl259. Dont worry about doing it yourself(if you have the right crimpers), they are pretty easy to put on, depending on if your coax is solid or stranded core.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
