Page 1 of 4 1234 LastLast
Results 1 to 30 of 110
  1. #1
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Whelen,Freedom,Responder parts,LED,strobes,Flasher,Talon,HLF,Moto,Sys9000, misc parts
    Outright sale on most of this stuff, but may consider trades depending on what you have and what I'm looking for. Everything works unless mentioned otherwise. If I have dates of manufacture, they're marked as such (DOM). If I don't have them, they're not listed. Most prices include shipping, so pretty firm on prices. Will combine shipping with a little leeway on prices if you buy several items.
    Wanted Thread:
    http://elightbars.org/f20/streethawk...174/#post71174
    Payment by money order preferred. Paypal, like it's red headed step child, eBay, continues to spiral down the crapper. So, it's no longer preferred, but will take it if ABSOLUTELY necessary on lower value items. Money order on anything over $150.
    Lightbars, Minibars, Lightheads, Dashlights & LEDs
    **Whelen Liberty corner module set - 4 qty. Blue. Back from Whelen on warranty repair. 3 repaired modules, 1 brand new. 4/09 manuf dates. 12LED. Looking to trade only for a similar/same set of amber, which can be older manuf dates.
    ** Code 3 XL minibar - 2 standard speed rotators, can switch one/both to fast. 795 bulbs. Red dome with several minor cracks, none all the way thru. Otherwise, dome is clear, some scratches, but not crazed. There's also a bunch of silicone on the bottom where it was apparently mounted w/o mounts. Also some writing that I cleaned up a little bit. Went thru it, re-wired, and cleaned it up, works good. $75 shipped OBO.
    ** Whelen Strobes - 52 and 500 series. Several used, 4 qty 500s, 3 qty 52s. Varying conditions, most have flaking of the reflector. Going to try and get some aluminum tape to rehab them like Richard P did to his Excalibur strobe. ~Tape applied, new pics~ First is original, second is w/ tape. 500s first 2, 52s second 2. No lens. All work. 500s = SOLD, 52s = $20 shipped/1 qty, 2 SOLD.
    ** Whelen Single Talons - prefer trade, have several other Talons in various configurations I'm looking for in my wanted thread. No shield or mount included in the trade to save on S&H weight and size. If purchase, buyer will have the option to add the shield and mount. Or, $60 shipped, shield/mount $5 additional.
    1. Non-sync. Standard 2 wire. Red w/ Clear lens. Passive. No label, but OEM Whelen as seen on lens pic. (next 3 pics)
    ** Fed Sig Highlighter LED dome - Blue. Good overall shape, 8-9/10 except for the 2 holes drilled thru to use carriage bolts to perm mount the lightbar to whatever. I'll try and fill with silicon if the seller wants. The holes are where the factory holes would be to hold the dome on, not some odd location. $15 shipped. ** Also have an amber one, complete w/o holes, 8/10 condition. $15 shipped.
    ** Federal Signal Vista filters - 5 blue rotator & 4 amber lower.blue lower. $1.50 ea + S&H. 2 blue rotator & 2 blue lower SOLD. Or, trade for other filters I'm looking for.
    ** SVP Hot shot dome - Believe it's NOS, but lots of storage scratches. Amber. Says 'old style' on the sticker. $10 shipped.
    **ShoMe/Nova/Able2 Microthin strobe lens - NOS. Pair in blue. Bought for lights, then sold the lights. $15 shipped.
    Siren/Controllers/Faceplates/Mounts/Brackets
    ** Code 3 RLS faceplate - I modified it by moving the cross brace down and notching it to fit a SS2000 head. $15 shipped.
    **Motorola System 9000 Siren Amp Lot - 3 amps, 2 wiring harnesses from amp to radio, 1 NIP control DEK, 1 used control DEK, 3 DEK-to-control head harnesses. Several brackets and misc parts. Amps and DEKs work fine, unable to test harnesses. $95 shipped.
    Flanges, Gaskets, and Shields
    ** 700 chrome set - 3 chrome flanges (2 matching, 1 different). Appx 10 various gaskets. Used $20 shipped.
    ** 400 gaskets - $7 shipped.
    ** LIN4 flange & gaskets - Apparently doesn't fit Whelen LIN4, not deep enough. Different design than Axixtech. What it actually fits, good question??? $5 shipped
    ** Whelen single Talon shields - NEW. Believe I have 7-10. $5 ea plus S&H
    Flashers & Other (see below slideshow for pics)
    ** AMP End kits - new plugs, new pins. Includes a complete plug (2 ends and respective number of pins/sockets). S&H additional. Can sub all one end or the other.
    -2 outlet kit (Liberty modules) - $1.00 ea
    -3 outlet kit (strobes/HAWs) - $1.50 ea
    -4 outlet kit - $2.00 ea
    ** Tomar HLF halogen flasher? - Model 930DM flasher. Used. Solid State. Negative switched. Searched and could only find info that this model is an LED flasher. But, it's marked halogen 12V and would only do a single alternating pattern @ about 60-70 FPM. Steady/override. Long wiring. $14 shipped.
    ** SoundOff Motorcycle HLF - Used, but like new shape. Solid state. Positive switched. Model ETETMM-P. Steady/override. Fast single alternating pattern. $15 shipped.
    ** Whelen Liberty module mounting spacers - Pair. Slides in between the corner and first module in the 52-54 inch bar. Was replaced with a TD kit. $10 shipped.
    ** Mobile Vision Siren Interface Box - Untested. Believe they're to let the video system know when the siren is activated. Not sure if they will work with other systems as well. 2 qty. $13 shipped ea.
    ** Whelen 24 volt bulbs - 2 NOS 70wt H1 bulbs. Motors not included, I found out how to convert them back to 12 volt. $19 shipped OBO.
    SOLD
    ** Fed Sig Highlighter LED - blue clear dome, mag mount.
    ** Whelen L32 beacon - red with red dome, mag mount.
    ** Whelen L53 beacons - 2 qty.
    ** 911EP TDWL36 - all Red.
    ** Whelen Responder LED housing, 2 qty
    ** LIN6 - Red, 2 wire, 3 qty.
    ** LIN6 - Blue, 2 wire, 14 qty.
    ** Dual Talon headliner mounts - 2 qty.
    ** LIN6s - 4 wire. 3 red, 2 blue.
    ** Whelen Dual Talon headliner mounts - TLNBKT2. NIP. 4 qty.
    ** Whelen Dual Talon - NIB/NOS. Red/Clear.
    ** Whelen Justice Towman's Bar - Model JF0BAAAA.
    ** Code 3 4/75 strobe kit. 2 qty.
    ** Whelen TIR6s - Blue. Pair. 2 wire.
    ** Whelen Dual Avenger - 9/08 DOM. Blue/Blue.
    ** Whelen Justice Towmans bar - NIP. Amber.
    ** Whelen Slimlighter brackets - pair. 2 qty pairs.
    ** Fed Sig LED Highlighter - Used Amber w/ choice of used amber dome or NEW clear dome.
    ** Whelen Dual Talon mount & shield - 1 NIP set, 1 used set.
    ** Whelen Dual Avenger - . Red/Blue.
    ** Whelen Responder LED flasher - 2 qty, both sold.
    ** FedSig SS2000SM - SD Version. Complete.
    ** L bracket mount - TIR3/LIN3/LINZ6. Dual pair & single pair. Silver finish.
    ** Whelen L11 beacon - Amber LEDs with Amber dome.
    ** Code 3 9x7 Prizm II 8 LED lightheads - Red/Blue/Red from top to bottom. NOS. 3 qty.
    ** Sho-Me LED flasher - Used. Model 11.1005SF. 2 qty.
    ** TIR3 grey flanges - 3 qty. Short model, grey color.
    ** Sound Off LED flasher - 12 outlet. Model ETFFC12LED.
    ** Sho-Me LED flasher - Used. Model 11.1007. Early model flasher?
    ** Stealth minibar internal domes - 3 red, 2 qty amber, 1 qty blue sold.
    ** Whelen PCC8R remote switch system - NIB and complete. 3/10 DOM.
    ** SoundOff HLF - Model ETQS00-P. Q-Switch flash pattern.
    ** Sho-Me HLF halogen flasher - Model 03.W3125. Random pattern.
    ** Galls/SoundOff HLF - Unk model, but wire colors and install the same as SoundOff. Multi pattern.
    ** Code 3 LC LED modules - Like new. Amber. 4 qty. 4 flash patterns and steady burn.
    ** 500 series surface mount - 5LSMAB. Several qty.
    ** SoundOff HLF - Model ETRR00-P. 3 qty.
    ** Austin Electronics/Whelen Rotobeam 6/RB6.
    ** ShoMe Stealth Internal domes. Blue. 2 qty.
    ** Whelen TIR6 - Blue. 4 wire. 4/08 DOM.
    ** Whelen Dual sync Talon - TLNS2BA. Blue/Amber. Ballast. 4 qty.
    ** Whelen TIR6 - Pair. Amber . 3 wire (pos, neg, sync). 1 flash pattern, sig alert.
    ** Galls/SoundOff TLF - Used/older. Model 'Traffic Backer'. Long wiring. 2 qty.
    ** LP LED brackets - Fits LIN4 sized module. New, unused.
    ** Whelen Centurion minibar - 2 rotators, diamond mirror. Red domes.
    ** Code 3 Narrowstick Controller - NIB. Can control 5, 6, or 8 LED lamps. Model NASL8DC.
    ** SoundOff TLF - Used, but like new condition. Solid state relay driven. Positive switched. Model ETFB00-P.
    ** SoundOff TLF - Used/older. Relay driven. Positive switched. Model 'Flashback'.
    ** Whelen Freedom board and internals - TXDPS model. Power distribution, flashers, and wiring.
    ** Whelen Freedom lightbar arrowstick harness - 15 ft w/ amp connectors on both ends. Includes internal lightbar harness.
    ** Whelen Freedom MR11 alley lights - 35 watts. Removed functioning. Pair.
    ** Whelen Freedom lightbar harness - 12+ feet, probably closer to 15. 13 positive wires, 4 ground wires, and shield/drain.
    ** Whelen RB6 beacon - NOS. 60 watt bulb non-H1 bulb. Amber dome. Perm mount.
    ** FedSig Legend lightbar - 45 in. Standard red/blue config with amber arrowstick.
    ** Federal Signal strobe power supplies - Model 416109. Silver Series 4A. Used, good condition. 3 qty.
    ** Federal Signal Vista filters - . 2 blue rotator & 2 blue lower SOLD
    ** Whelen Micro Liberty - Custom minibar. Blue 12LED corners. New lens.
    ** Whelen Slimlighter - SLPLLAA, 5mm modules. Amber/Amber. NIB. 3/2012 manuf date.
    ** Whelen Justice /Responder LED Modules - CON3. NOS/Demo. Amber. 10/10 DOM. 6 qty.
    ** Federal Signal Dynamax Bracket - for CVPI late model, or possibly others. Used.
    ** Whelen Freedom lens kit - Fits standard 50in bar.
    ** Whelen Guardian G8 minibar - NOS/demo, 1/08 DOM. G8VCBB. 2 L22 Blue LED beacons.
    ** Federal Signal Legend mounting feet - Old style, but still useable.
    ** Whelen ULF22 LED flasher - NOS
    ** Whelen CS220 strobe PS - NOS. 2 outlet, 20 watts. Waterproof. Several scan-lock patterns.
    ** Whelen Liberty lens sections - NOS, some surface storage scratches. 2 qty 15 3/4 inch sections.
    ** Whelen TIR3 cast flanges - NOS. Includes 4 mount screws. Part #RFLANGEA.
    ** Whelen Freedom corner modules - New style w/ 18 LEDs and diffuser. Blue. 4 qty.
    ** Whelen Freedom/400 module - New style w/ diffuser. LIN6 Blue on top, LIN3 depop Amber on bottom. 6 qty.
    ** Code 3 XL minibar dome - Red w/ red endcaps. 8.5-9/10 for condition.
    ** Fed Sig Highlighter dome - Tall, for rotator or strobe bar. Amber. 7-8/10 condition, no cracks, just sunfade & haze.
    ** Whelen Liberty lens - Fits standard 48in bar.
    ** Whelen Edge 9000 endcap - NOS. All amber, no alley cutout.
    ** Whelen LED flasher - unk model, appears to be a heavy duty unit, like on a DOT/construction truck. 6 outlets.
    ** Whelen Justice/Resonder LIN6 module - 2 qty/pair. Blue. 11/10 manuf date.
    ** Whelen Freedom corner module - Blue. Brand new, unmounted. 5/12 manuf date.
    ** Whelen Liberty 500 halogens - Standard takedown or alley light. 27 watts. Pair.
    **Whelen DashMiser Custom LED dash/decklight - 2 duals w/ 4 5mm LED modules.
    ** Code 3 Prizm II LED boards - REF8 amber boards. NIP.
    ** Whelen Mirrorbeam kit - NEW, unmounted. Fit 00-06 Chev Impala.
    ** Whelen Responder LED minibar housing - Clear dome, poly base.
    ** Whelen Strobes - 52 and 500 series. Several used, 4 qty 500s, 2 qty 52s
    ** Custom LED minibar - Whelen Responder LED minibar housing, 8 NEW unk make TIR4s in amber, LED flasher, NEW switched plug.
    ** Whelen Talons:
    1. Sync. Blue w/ Clear lens. Passive.
    2. Sync. Blue w/ Blue lens. Ballast.
    Ryan
    "Blessed are the peacemakers, for they will be called sons of God." Matthew 5:9
  2. #2
    Author of This Thread
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Added some pics of new items.
    Ryan
  3. #3
    Moderator
    shues is offline
    Joined May 2010
    NW Indiana
    Does the Whelen LED Responder housing happen to contain the flasher and wiring?
  4. #4
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Quote Originally Posted by shues View Post
    nope
    Ryan
  5. #5
    Moderator
    shues is offline
    Joined May 2010
    NW Indiana
    Ok, thanks anyway!
  6. #6
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Sold items removed, revised some of the descriptions with more info.
    Ryan
  7. #7
    Fire/EMT
    Professional Upfitter
    factorone33 is offline
    Joined June 2010
    Overland Park, KS
    I'll take two of the LIN6 red liberty modules. PM sent.
  8. #8
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    sold items removed
    Ryan
  9. #9
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    updated again
    Ryan
  10. #10
    FFEMT75 is offline
    Joined June 2010
    Houston, Texas
    payment sent for Whelen Dual Talon headliner mounts - TLNBKT2. NIP. 4 qty. $14 shipped ea. 2 sold, 2 remaining
  11. #11
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Updated
    Ryan
  12. #12
    Volunteer Fire Fighter
    ff_coddington is online now
    Joined October 2010
    smithfield,pa
    do you have any lightbars in all blue?
  13. #13
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Quote Originally Posted by ff_coddington View Post
    No, I don't have any full lightbars in blue. I do have the Guardian mini, but with your threads, I gathered you were trying to sell off your Falcon and dashlight for a full bar.
    Ryan
  14. #14
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Ryan
  15. #15
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Sold items removed.
    Ryan
  16. #16
    EMT
    Transportation
    Jhart911er is offline
    Joined April 2011
    North east pennsylvania
    Slimlighter mounts
    Are the slimlighter mounts still available? What style? Suction cup or L bracket perm mount?
    Thanks
    Jeremy
  17. #17
    Newbie
    Law Enforcement
    spd40 is offline
    Joined April 2011
    US/Oklahoma
    Whelen Duel Talon mount
    I would like to purchase the Whelen Dual Talon mount & shield $15 shipped for the used. Can you email me to let me know what I need to do. Thanks
  18. #18
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Quote Originally Posted by Jhart911er View Post
    Thanks
    Jeremy
    Just as pictured, they're the L-brackets for the ends. I should be able to dig some suction cups up.
    Quote Originally Posted by spd40 View Post
    PM me and I'll walk you thru it.
    Ryan
  19. #19
    EMT
    Transportation
    Joined April 2011
    Quote Originally Posted by rwo978 View Post
    Payment Sent for Slimlighter Brackets!!!!
  20. #20
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Thanks. Didn't have a chance to get them together this morning, hard court after I got done with work. Will try and get them together and dropped off tonight when I head to work again.
    Ryan
  21. #21
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    sold items removed, lowered some prices.
    Ryan
  22. #22
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    sold items removed
    Ryan
  23. #23
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    more sold items removed.
    Ryan
  24. #24
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Added PCC8R, it's a bit much for a set of HAWs, HLF, and TLF...
    Ryan
  25. #25
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Updated
    Ryan
  26. #26
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Updated, added new items.
    Ryan
  27. #27
    EMT
    Volunteer Fire/EMT
    EMS_Installer is offline
    Joined February 2011
    Clackamas Co. ~ OR
    PM Sent
  28. #28
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Updated. Sold items removed. Lots of flashers added. HLFs, TLFs, and LED flashers. Discounts for multiple items purchased.
    Ryan
  29. #29
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    More sold items removed and a couple prices lowered.
    Ryan
  30. #30
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Sold items removed.
    Ryan
Posting Permissions
  • You may not post replies
  • You may not edit your posts
