Results 1 to 7 of 7
  1. #1
    Author of This Thread
    Junior Member
    irwinpd54 is offline
    Joined March 2011
    Pennsylvania
    Motorola XTS2500 portables and XTL2500 mobiles
    A local municipality has switched from 800 to UHF and we have purchased the radios. I have sold almost half the lot and I'm throwing them on here to see if theres any interest.
    Motorola XTS2500 series I portable includes:
    Impress charger
    New Impress battery
    Appropriate flash information if supplied by customer.
    AND
    Motorola XTL2500 series mobile (Currently dash mount but could be remote if neccesary with a slight upcharge)
    Antenna mount with "Phantom" Motorola antenna
    Power cord
    Palm microphone
    Speaker
    I have sold them all locally for $1100.00 but I will let them go for $1000.00. I am into each radio for 900.00 plus the cost of the new batteries, antennas and power cables.
    [COLOR="#FF0000"]XTS 2500 Specification
    Standard battery chemistry type
    Nickel Cadmium, Nickel Metal Hydride
    Encryption type / Algorithms
    AES, DES, Advanced Digital Privacy (ADP)
    Channel spacing 12.5, 25
    Programming software allows adjustable power output for varying coverage
    Frequency range 764-870 MHz
    Power 1–3W—700/800 MHz
    Radio Features
    Number of channels 48 (Model I; 96 (Model 1.5); 870 (Models II & III)
    CPS (Customer Programming Software)
    Noise reduction software
    Integrated voice and data
    Man down
    Text messaging
    Advanced Software Features
    Over the Air Programming (OTAP)
    Mil spec 810 C, 810 D, 810 E, 810 F
    Submersible
    Digital technology
    System type Conventional, SmartZone trunking, SMARTNET trunking
    XTL2500 Series Mobile Specs
    Encryption
    Power levels 10-35 Watt (764-870 MHz)
    Encryption type / Algorithms: AES, DES, DES-XL, DES-OFB, Advanced Digital Privacy (ADP)
    Configurations
    Dash Mount, Remote Mount Capable
    Display: Alphanumeric
    Channels 870
    Text messaging capable
    Advanced software features
    Over the Air Programming (OTAP), Over the Air Rekeying (OTAR)
    Digital technology
    System type: Conventional, SmartZone trunking, SMARTNET trunking
  2. #2
    Law Enforcement
    Security
    PTRJason is offline
    Joined July 2010
    Menifee, CA
    Do you have nay photos?
  3. #3
    Junior Member
    Joined March 2011
    Pennsylvania
  4. #4
    Veteran
    Law Enforcement
    Towing
    Vintage Collector
    kadetklapp is offline
    Joined May 2010
    Indiana
    Disregard.
  5. #5
    Junior Member
    Joined March 2011
    Pennsylvania
    Bump
  6. #6
    Newbie
    Law Enforcement
    Communications
    Professional Upfitter
    Spectragod is offline
    Joined August 2011
    Ohio
    What are the flash codes on the mobiles, as well as the HOST and DSP?
  7. #7
    medic550 is offline
    Joined May 2010
    pa usa
    I did the updating on the mobiles.
    Ver 15.10
    Flashcode presently 589088-901484-1
    portables are A revision 4 meg with f/w 9.20 dsp 15.05 same flashcode
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
