Results 1 to 11 of 11
August 1st, 2012, 04:08 PM #1
Correct bulb for solar ray model 18 bulb question
What is the correct sealed beam bulb to go under a red lens in a 12 volt solar ray light?
August 1st, 2012, 08:24 PM #2Member
- Joined May 2010
Hudson Valley New York174 Posts
August 1st, 2012, 08:43 PM #3
Right now I have a red bulb under a red lens, so I know the bulb is wrong... I can't find any markings on it though... any idea what number or type it is?
August 1st, 2012, 09:07 PM #4
It has a 4436 r in it now... I'll use a 4436 clear bulb I think... is fluted the correct style?
August 1st, 2012, 09:07 PM #5Member
- Joined May 2010
Hudson Valley New York174 PostsI would have to take a closer look at it (take it apart). It looks like an old style automotive type headlamp. Let me see what I can find out.
August 1st, 2012, 09:12 PM #6
August 1st, 2012, 09:19 PM #7Member
- Joined May 2010
Eastern Missouri97 PostsIs it 6 or 12 volt?
edit... DUH nevermind.
Its definately a fluted bulb. The beam is like a fog light pattern, wide (side to side) and narrow (top to bottom). The beam pattern is what gives the flash effect.
Mine is a 6 volt so it wont help you.
August 1st, 2012, 09:28 PM #8Member
- Joined May 2010
Hudson Valley New York174 PostsIt is a fluted bulb (I could not recall the correct word for the bulb). I remember John Dorgan telling me. I know I have a federal ad jpg that describes the type of bulb, but you are correct, its fluted.
August 1st, 2012, 10:23 PM #9
August 2nd, 2012, 07:23 AM #10
4413
I want to live where a chicken can cross the road without her motives being questioned.
August 2nd, 2012, 05:47 PM #11Veteran
- Joined February 2011
Midland, TX1,592 PostsThat should do you, John, unless you really want to make it bright with a halogen sealed beam!
I saw something interesting on Ebay. A guy has an old Mars light that is labelled as an 888, but it has a 1019 bulb (like a jr. beacon). I suspect that it may be an old DL8. You might want to take a look under "Mars light".
LinkBack URL
About LinkBacks
992 Beacon
994 Beacon
Commander 5200
Commander 5200
Commander 5200
Freeze alarms, deputy and Clear-Ray
Mini Advantedge
Oscillating Commander
Oversized beacons
Sireno 300
Stinger
Strobe Commander
Strobe Commander
Strobe Commander
Whelen 80H-5
Whelen 994
Horton Ambulance
Tons for sale
Today, 09:09 AM in For Sale or Trade: Warning Equipment
