Page 1 of 2 12 LastLast
Results 1 to 30 of 32
Thread: Dietz 211?
  1. #1
    Author of This Thread
    Veteran
    Law Enforcement
    Security
    Dealer
    MEVS06 is online now
    Joined May 2010
    San Antonio, TX
    Dietz 211?
    Hello all, I just got this and have no idea what its worth. I would really appreciate any info you l can give me on this. I dont plan on keeping it so please let me know what it may be worth. As you will notice the dome is cracked. I am not to sure if it works or not but I will test it asap. Thanks
    EDIT: I was able to test it and it does work. All four bulbs lit up and it did rotate.
    Joe - Texas LEO
    MOR Emergency Vehicle Solutions
    morevs.911@gmail.com
  2. #2
    Volunteer Fire Fighter
    Security
    Professional Upfitter
    rofowacker is offline
    Joined September 2010
    Montgomery County PA
    I have. or will shortly me acquiring a NOS red dome, if your interested!
    Live, Learn, Experience!
  3. #3
    Veteran
    stansdds is offline
    Joined May 2010
    U.S.A., Virginia
    You have a very basic Dietz model 211. The serial number on the badge indicates it was made in 1966. If it is all original, there will be a date stamped in ink on the motor, it should also be 1966, but a beacon made at the first of the year might have last year's dated motor. You do have the mounting gasket, something that is usually missing.
  4. #4
    Veteran
    Law Enforcement
    Security
    Dealer
    Joined May 2010
    San Antonio, TX
    Thanks everyone, what would this be worth. I may take you up in that NOS.
    Joe - Texas LEO
  5. #5
    Law Enforcement
    Vintage Collector
    Hobbyist
    flahotrod is offline
    Joined August 2011
    Florida
    Pinball Charlie would be a good source for your question. He is quite knowledgeable on Dietz 211 & 711 beacons.
  6. #6
    PinballCharlie is offline
    Joined October 2010
    Kingston NY
    Quote Originally Posted by flahotrod View Post
    Hey, I am a sucker for these lights. When I see them for sale I usually end up buying them. I would say your light is worth $60 the way it is and then if you put on a NOS lens, the price would go to $100.
    Nice light for your collection though.
    Pinball Charlie
  7. #7
    Veteran
    Law Enforcement
    Security
    Dealer
    Joined May 2010
    San Antonio, TX
    Quote Originally Posted by PinballCharlie View Post
    Pinball Charlie
    Thanks, this is actually the first vintage light I have had my hands on and I am unsure if I should keep it or not. Hmmmm pondering the thought. Its very clean inside. Pic to come.
    Joe - Texas LEO
  8. #8
    Veteran
    Law Enforcement
    Security
    Dealer
    Joined May 2010
    San Antonio, TX
    Joe - Texas LEO
  9. #9
    Veteran
    stansdds is offline
    Joined May 2010
    U.S.A., Virginia
    Looks nice on the inside, definitely worth a new dome. If you clean the inside, do not clean the motor with any sort of solvent as that will remove the markings on the motor.
  10. #10
    Veteran
    Law Enforcement
    Towing
    Vintage Collector
    kadetklapp is offline
    Joined May 2010
    Indiana
    Well this one is on it's way to me, to be put in service on a work-truck. I didn't realize it was that old honestly. I figured late 70s, early 80s. Shopping for a clear or amber replacement dome now...
  11. #11
    Veteran
    Law Enforcement
    Towing
    Vintage Collector
    Joined May 2010
    Indiana
    Well I received the light yesterday. Finish is in pretty good shape for the age. First thing I noticed is that the rotating assembly is mounted way off center inside the "pan" (lower housing). It would appear someone for some reason has moved the motor assembly around and lined it up in the wrong holes. I could be wrong. Anyone else have a Dietz setup like this? I will try and snap a picture tonight. Basically it looks like this-
    Anyway, just looking for some guidance here, rather than start a new thread.
  12. #12
    Communications
    EMT
    Steve0625 is online now
    Joined June 2010
    Northville NY
    Quote Originally Posted by kadetklapp View Post
    The center post of the rotating unit should be in the center of the base. Sounds to me like someone took it apart for cleaning or a repair and didn't quite put it back together correctly.
    Dispatcher II - Rochester/Monroe County (NY) Emergency Communications (E-9-1-1) March 1976 to October 2003 - Retired and loving it!
    Northampton Ambulance Service
  13. #13
    Joined October 2010
    Kingston NY
    I would remove the bolts, center it the best you can, mark it with a sharpie and drill new holes. Problem solved!
    Pinball Charlie
  14. #14
    This is the California version of the 211! This is about as rare a pice as I've seen!!!!!!
    There is supposed to be a steady burn red light mounted in the larger open area, and this is the front of the light.
    This way everything is enclosed under the dome / lens.
    Heard enough?
    Just kidding!
  15. #15
    Veteran
    stansdds is offline
    Joined May 2010
    U.S.A., Virginia
    Quote Originally Posted by Steve0625 View Post
    My thoughts exactly.
    Just because you can do something doesn't necessarily mean that you should do it.
  16. #16
    Veteran
    Law Enforcement
    Towing
    Vintage Collector
    Joined May 2010
    Indiana
    IDK about drilling any more holes. In looking at this, there are several holes already in the bottom of the pan. Drilling more is just going to make it flimsy on the bottom...
    So, I'm trying to just take it apart and align it properly, but this has been a challenge. The screws are absolutely tighter than hell, so it's a struggle to get them out in one piece. I've removed ONE so far. I think I'm going to have to break out the Dremel.
  17. #17
    Veteran
    Law Enforcement
    Towing
    Vintage Collector
    Joined May 2010
    Indiana
    I took this apart. I'm not sure what the deal is, but the holes are reinforced (threaded) and the only way to mount this is in the holes with the reinforcement. Not sure why this is like this, as it appears to be stock and unmolested. Very odd.
  18. #18
    Veteran
    stansdds is offline
    Joined May 2010
    U.S.A., Virginia
    I took down one of mine to have a look. Are you absolutely positive that the post for the lamp carrier assembly is off-center? My motor and drive are mounted just like yours, but the post is in the center of the dome and base. Besides, I don't think there is enough room inside the dome for the lamp carrier to be off-center and still rotate.
  19. #19
    Veteran
    Law Enforcement
    Towing
    Vintage Collector
    Joined May 2010
    Indiana
    Yea, I'm positive. Here's a good view-
    Note the center of the lens marked by the mold mark is way off from where the center post of the rotating assembly is.
    Here's the pan with the rotating assembly removed-
    The smaller holes with the circle around them appear to be the correct mounting holes. I'm thinking this just was a shoddy job at the factory. It's not even close to centered and you can only mount the motor one way as far as I can tell.
  20. #20
    Law Enforcement
    Vintage Collector
    Hobbyist
    Joined August 2011
    Florida
    I would agree. It looks like someone said "Good enough" and packaged it up.
  21. #21
    Veteran
    stansdds is offline
    Joined May 2010
    U.S.A., Virginia
    Thanks for the pics, I see it is off center just a little, not enough to affect function, but enough to be visible. The base looks correct, I don't see where any of the motor mounting holes have been modified. Could well be that this beacon was either a Friday last one for the week or a first one on Monday with a hangover.
  22. #22
    Volunteer Fire/EMT
    Vintage Collector
    Wigwam700 is offline
    Joined May 2011
    New York Adirondacks US
    are you still selling this light? And how much?
  23. #23
    Newbie
    gasgzlr is offline
    Joined February 2012
    Canada, Moncton, New Br
    Talking Dietz 211.... 7-110
    Hey Guys, I am a newbie. I joined this forum just to be able to access the vast knowledge base available.
    I have had a Dietz 211 it also has the numbers 7-110 and more info such as SAE-W3-70. The serial number is 07-1570.
    It has a red dome that has a few scratches but no cracks. The sealed beams are all missing and I would like to replace them, what bulbs would I need? I think everything else is there.
    Any help would be great!!!
  24. #24
  25. #25
    Veteran
    Collector
    Vintage Collector
    CrownVic97 is online now
    Joined May 2010
    Hazen, ND
    Interesting enough, I found another "It's finally Friday" or "Monday hangover" Dietz 211 with an off-center rotator assembly while roaming eBay. Your's is not the only one, Kadet!
  26. #26
  27. #27
    Joined October 2010
    Kingston NY
    I actually had one that was way off center. Somebody was probably smoking the wacky weed!
    I ended up drilling new holes and it looked much better! That one got traded towards an Aero bar...
  28. #28
    Veteran
    Law Enforcement
    Towing
    Vintage Collector
    Joined May 2010
    Indiana
    I've got to say, this being my first Dietz rotator, I'm not too impressed with the build quality. The rotating assembly is not only off center, but appears to be bent up. I had to shim two of the screws holding the motor to the bowl to get it to even sort of sit evenly in the pan.
  29. #29
    Veteran
    stansdds is offline
    Joined May 2010
    U.S.A., Virginia
    eBay purchases can be like a box of chocolates, you never know what you are going to get.
    I've gotten some real gems on eBay, I've gotten some junk. With used pieces of emergency equipment the seller often doesn't know what he has or how to properly evaluate it, so it can be a roll of the dice as to what it will be when you open the box.
  30. #30
    Veteran
    Law Enforcement
    Towing
    Vintage Collector
    Joined May 2010
    Indiana
    Quote Originally Posted by stansdds View Post
    Didn't buy it off ebay, bought it from the OP. Not that it matters, but I digress.
    This is going to get tossed on the work truck and banished to a life of hard work. Once I found out how old it was I was considering putting it in the display case, but I'm so disgusted with it that I'm sentencing it to a life of hard labor. I've got some log trailers to pull and this fits the bill.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
