Results 1 to 10 of 10
  1. #1
    Author of This Thread
    Senior Member
    Law Enforcement
    plybeep68 is offline
    Joined August 2011
    Jonesborough TN
    Help Identifying a part
    I received this base in a trade a while back and don't have a clue to what make it is? Not sure if i even posted in the right thread! No name on it anywhere, even on the motor.
  2. #2
    Veteran
    Transportation
    toon80 is offline
    Joined May 2010
    Montreal, Canada
    Looks like a Dietz 2-11 base. I have seen Signal Stats that looks like it also.
  3. #3
    Veteran
    Collector
    Vintage Collector
    CrownVic97 is online now
    Joined May 2010
    Hazen, ND
    I'm leaning towards Signal Stat on this one. Signal Stat bases always went narrow towards the bottom like that and the two-beam version of this was pretty common.
    From a craigslist ad:
  4. #4
    Senior Member
    Law Enforcement
    Joined August 2011
    Jonesborough TN
    Seems like they should have used 4 bulb set-up's, at least would have looked better! I do like the contour/slope of the domes on the Signal Stat
  5. #5
    Veteran
    Collector
    Vintage Collector
    Joined May 2010
    Hazen, ND
    Quote Originally Posted by plybeep68 View Post
    They did have 4-bulb beacons in this design as well. Most famous use for these beacons is with the NYPD in the 1970s.
  6. #6
    Veteran
    Transportation
    toon80 is offline
    Joined May 2010
    Montreal, Canada
    I have close to NOS like these NYPD ones near my place but are amber domes....
  7. #7
    Senior Member
    Law Enforcement
    Joined August 2011
    Jonesborough TN
    The NYPD set-up is Nice!!! Who made the can lights?
  8. #8
    Veteran
    Fire/Paramedic
    Vintage Collector
    Security
    Hoser is online now
    Joined June 2010
    Ohio
    They almost look to be McDermott can lights, it looks like the little signal stat lolipops are on McDermott risers, as they are staggered on the 2 rails.
  9. #9
    guy m. is offline
    Joined May 2010
    Pike County Pennsylvania
    Quote Originally Posted by Hoser View Post
    The can light's are TRIO Sales T-2 PAR 46 lights, same as the ones that LAPD used.
  10. #10
    Senior Member
    Law Enforcement
    Joined August 2011
    Jonesborough TN
    Was that set-up something that NYPD did in house or did they purchase thru Signal Stat?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
