Results 1 to 28 of 28
Like Tree3Likes
  • 2 Post By badge22
  • 1 Post By JohnMarcson
Thread: Lp6000 cal
  1. #1
    Author of This Thread
    Collector
    denko3 is online now
    Joined July 2010
    SLOVENIA,EUROPE
    Lp6000 cal
    Hey guys!
    can someone please help me and tell me which bulbs had lp6000 CAL in the bar and what was the configuration?
    any pics would be great.....
  2. #2
    Quote Originally Posted by denko3 View Post
    Hey guys!
    There is no single CA setup for an LP 6000. The red steady light was a full sized stationary light with a 50w bulb I believe.
  3. #3
    Quote Originally Posted by JohnMarcson View Post
    I dont think a full size stationary bulb would fit in the LP6000 I think you are thinking of the XL model.
    Lol sorry John, I was thinking full size sealed beam, Denko John is correct it would have a stationary light, the type used as the takedowns or flashers with a 50w bulb.
    I love Winky Blinkies, especially MARS products!
  4. #4
    Senior Member
    badge22 is offline
    Joined August 2010
    MI, United States
    I THINK they used a stationary reflector that had a special coated reflector for the front stationary RED. Kinda looked liked it was unpolished.
    We the willing, led by the unknowing; have been doing the impossible for the ungrateful. We have been doing so much for so long with so little; we are now qualified to do anything with nothing.
  5. #5
    Junior Member
    Benno is offline
    Joined July 2011
    Germany, Lower Saxony
    The stationary reflector is not coated.
    The reflector is frosted! Except for a small area in the middle (behind the Typ795 bulb).
    The Setup of the LP is:
    Alley-light - rotator - diamond mirror - steadyburn/rear-flasher - speaker center - front- /rea-flasher - takedown/half diamond mirror - rotator - alley-light
  6. #6
    Senior Member
    badge22 is offline
    Joined August 2010
    MI, United States
    Quote Originally Posted by Benno View Post
    Ok, so if you "frost" something, are you not putting a coating on it?
  7. #7
    Junior Member
    Benno is offline
    Joined July 2011
    Quote Originally Posted by badge22 View Post
    Not necessarily!
    Looks like sand blasted. That´s the easiest way to "frost" something.
  8. #8
    Collector
    Joined July 2010
    SLOVENIA,EUROPE
    WOW never seen a stationary reflector like that,was it a factory made? it looks like there it was spray it after they made it. :-)
    thanks for set-up Benno but is this the only setup or was there any other maybe?
    John,so the bulb for CAL red is 50W isn't this too hard usually the CAL in lightbars were less the 30W,what do you think? i got the 50W in mini vector and it's very strong.
    yes Jenny i now what you ment about stationary light in XL.... :-)
    folks what about domes red and blue set-up?
    and is there a possibility to change the lp rotator reflector with mx or xl reflector is it hard,what you must take off if i want to do that?
    is it just a ring or anything else maybe?
  9. #9
    jdh
    Senior Member
    Collector
    jdh is online now
    Joined May 2010
    Maitland, Fl.
    I have seen set ups with, (Pass to Driver) alley, rotator, blue steady burn(rear blue flasher), sting ray, speaker cover, sting ray, red steady burn(amber rear flasher), rotator, alley.
    And that is a weird reflector. i have worked on thousands of LP6000 and I have never seen one quite like that.
  10. #10
    Collector
    Joined July 2010
    SLOVENIA,EUROPE
    thanks for this set-up too! maybe was this set-up old CHP cars??????? :-)
    yes i see the first time sended lp reflector????
    Quote Originally Posted by jdh View Post
  11. #11
    Senior Member
    badge22 is offline
    Joined August 2010
    MI, United States
    Not necessarily!
    Sandblasting is not frosting something. I have never seen a cake sandblasted.
    gfpd26 and kitn1mcc like this.
  12. #12
    I have a factory LP CA setup with the steady burn being a fully polished reflector too... so they used a few things... I have also seen both used in the XL.
  13. #13
    Collector
    Joined July 2010
    SLOVENIA,EUROPE
    can someone list some pics from domes which is the original set-up?
  14. #14
    There is no one CA setup...
    Most had outer rotators front diver steady red, front passenger takedown.. other options varied a lot. Any LP that has full size flashers or takedowns could have one replaced with a steady burn.
  15. #15
    Collector
    Joined July 2010
    SLOVENIA,EUROPE
    isn't there the reat cut out amber flashers in domes?
  16. #16
    jdh
    Senior Member
    Collector
    jdh is online now
    Joined May 2010
    Maitland, Fl.
    The CAL LP6000 that I called out in my above post has solid colored domes with bullet cutouts for the alleys and 1 amber cutout in the red dome to the rear.
  17. #17
    Junior Member
    Benno is offline
    Joined July 2011
    ...And that is a weird reflector. i have worked on thousands of LP6000 and I have never seen one quite like that.
    I think Code3 called the Reflektor "Stationary Partially Textured Reflector Assembly (S45023M)" or "50w Partially Textured Stationary Module (S45024M)". But i´m not sure!
    My LP has blue/red domes with small bull´s eyes for alley and one large bull´s eye for takedown.
  18. #18
    Guru
    Hobbyist
    chief1565 is online now
    Joined March 2011
    Slaterville/NY
    Sorry don't take Paypal/exceptions USPS money orders or cash or Walmart #5240 transfers ONLY.
  19. #19
    Senior Member
    Law Enforcement
    ford-dealer is offline
    Joined September 2010
    San Antonio
    If my memory is correct, didn't CA bars require the black plastic siren speaker housing that allowed a NO-LP style speaker to be installed? I am thinking I remember seeing a CA Title XIII designation on that option in the original sales brochure.
  20. #20
    Quote Originally Posted by ford-dealer View Post
    It had a Ca compliant speaker available... but many had no speaker at all. CA LP were just any LP with at least 2, usually 4, fullsized stationary reflectors.... 1 was steady burn and under a red filter or dome... and at least 1 was almost always a rear amber flasher. Add in the fact that you could use reflector mounted or reflector surrounding filters or colored domes with cutouts... the setups were endless. LPs were under rated bars.
    6236 was a commonly "CA converted bar", as were 6296 and 6349 if one were into stingrays...
  21. #21
    lite-em-up is offline
    Joined May 2010
    Eastern Missouri
    Your memory IS correct. In order for a LP BAR Mounted speaker to meet Cal requirements, you must use the black "class A" speaker cover. It resembled a JetSonic speaker in a way. The regular chrome LP speaker cover required the speaker bell to be cut at an angle in order to fit under the cover. The cutting of the bell no longer meets the Class A requirements.
    As for the stationary light, In order to TRULY meet Cal requirements the red steady burn required the frosted stationary light. The "frosting" was a special coating that was placed on the reflector by the supplier to Code-3. Instead of the smooth, highly polished reflector it would be rough and dull in finish. The pic above is the correct stationary light.
    From the sales brochure:
    Many of the bars that I saw go out of the factory to Cal were either under a red lens with clear bulls-eye to the rear for the amber flashing light. The stationary light behind the bulls-eye had an amber filter on it.
    OR
    Clear lenses with colored filters
  22. #22
    Senior Member
    Law Enforcement
    San Antonio
    That is the exact brochure I remembered seeing it in.
  23. #23
    Collector
    Joined July 2010
    SLOVENIA,EUROPE
    huh guys i now more than i thought! :-)
    thanks didn't now all that usually i get in fedsig lights and lightbars not so much in code3.
  24. #24
    Veteran
    NPS Ranger is offline
    Joined May 2010
    Penn's Woods
    Quote Originally Posted by lite-em-up View Post
    You gotta love Kalifornia, trimming a speaker bell as used in the other 49 states doesn't meet their rules so a whole new speaker cover is required just for their state... but yet a single red spotlight is perfectly safe and adequate by itself as a warning light.
  25. #25
  26. #26
    Collector
    Joined July 2010
    SLOVENIA,EUROPE
    was the speaker housing custom made then?
    Here's mine, all the stationary lights are frosted. There was never a speaker mounted. It used to have stingrays...
  27. #27
    No.. it's just a regular grill with nothing behind it. The speaker for this unit was elsewhere... probably on a push bumper.
  28. #28
    Collector
    Joined July 2010
    SLOVENIA,EUROPE
    would like to see one with solid red and blue domes if someone will post a pic maybe,i hope.....someone????
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
