Results 1 to 19 of 19
Like Tree5Likes
  • 4 Post By dmathieu
  • 1 Post By AKRLTW
Thread: Rota-beam hill light
  1. #1
    Just when you think you've got it all down pat, you learn something new.
    Interesting thing on version 3 Aircraft Rota-Beam is that it has 6 extra glass lenses under the dome. Other than the 3 round main magnifying lenses, in the 3 connecting sides of the lens cage, (see picture), there are half circle glass magnifying lenses in each of the cut-outs. These lenses catch the bulb filament at high and low angles, while the main lenses catch the horizontal.
    This gives HIGH, LEVEL, and LOW beams, 3 of each, on each rotation.
    Almost a HILL LIGHT effect.
    The automotive version of this light, (Model 66), does not have this feature.
    Attached Images Attached Images
  2. #2
    Senior Member
    MESDA6 is offline
    Joined June 2010
    Central IL
    That is a cool light! Why do I have a feeling you will have a blue dome on that at some point?
  3. #3
    Quote Originally Posted by MESDA6 View Post
    Good thought!
    But I think I'll keep it as an aircraft light, in the original aircraft red.
  4. #4
    Junior Member
    stuporduck09 is offline
    Joined June 2010
    Jax Fl
    That's Sharp...Any Vids?...
    CRUSH ALL SMOKES,KILL THE RED REALY DEAD!!!
  5. #5
    Fire/EMT
    Military
    AKRLTW is offline
    Joined January 2012
    AK/NV USA
    I think that'd be pretty sick to see in some snow or fog.
    nerdly_dood likes this.
  6. #6
    Sorry, youv'e never seen a video from me. I'm a video challenged, low tech kinda guy.
  7. #7
    Senior Member
    guy m. is offline
    Joined May 2010
    Pike County Pennsylvania
    Cool
    WoW, never seen one like that before, very cool!
  8. #8
    Senior Member
    EMT
    jph2 is online now
    Joined April 2012
    USA Michigan
    Ditto. Never knew that; thanks for sharing.
  9. #9
    Moderator
    Emergency Management
    Law Enforcement
    Military
    unlisted is offline
    Joined May 2010
    Canada
    Quote Originally Posted by guy m. View Post
    and that my friends, is what makes aircraft lights cost at least $500.00 more than their automotive counterparts...
    beautiful light. . send it my way, I have a great video camera. I'll do the video for ya.
    An annoyance online since original BBS days- early 90's. Damn I miss modem tones... but not 14.4 kbit/s.
    You know what the chain of command is? It's the chain I'm going to get and beat you with until you understand who's in command here.... (best quote ever!)
    I collect green lighting. Let me know what you have!
  10. #10
    Senior Member
    Law Enforcement
    Vintage Collector
    patrol530 is online now
    Joined May 2010
    Central Florida
    Neat, I'd never really paid any attention to the holes in the cage.
  11. #11
    Original style lens cage with top rect. cut out.
    Newer style lens cage with cut outs.
  12. #12
    Quote Originally Posted by unlisted View Post
    Actually the certifications are more expensive to maintain for the production of aircraft parts.
  13. #13
    Guru
    Fire/Paramedic
    Vintage Collector
    Retired
    Hoser is online now
    Joined June 2010
    Ohio
    Smile
    Hills and aircraft mean trouble .....
  14. #14
    Veteran
    NPS Ranger is online now
    Joined May 2010
    Penn's Woods
    You might be able to date the light from the Federal Air Regulations for anticollision beacons:
    Aircraft for which type certificate was applied for After April 1, 1957 to August 10, 1971:
    These anti-collision systems must produce a minimum of 100 effective candela in Aviation Red or White (REF. FAR 23.1397), 360º around the
    aircraft’s vertical axis, 30º above and below the horizontal plane (REF. FAR 23.1401).
    Aircraft for which type certificate was applied for After August 11, 1971 to July 18, 1977:
    These anti-collision systems must produce a minimum of 400 effective candela in Aviation Red or White (REF. FAR 23.1397), 360º around the
    Aircraft for which type certificate was applied for After July 18, 1977:
    aircraft’s vertical axis, 75º above and below the horizontal plane (REF. FAR 23.1401).
    I would suspect your light was made to meet the 3rd spec, but that was the time that strobes were starting to take over the market and I'm sure there weren't a whole lot produced of that model. Very nice!
  15. #15
    Veteran
    Military
    nerdly_dood is online now
    Joined June 2010
    California
    Christ on a pogo stick.
    By "Veteran" they mean that I post too much. Not related to the nearby word "Military." Currently in training to be a Chair Force desk warrior.
    Fewer, slower, bigger. (Usually.)
    If you're doing it because it looks cool, it's probably a bad idea. Unless an AeroTwinsonic is involved, in which case it's automatically both cool and an excellent idea.
  16. #16
    More pics of added magnifiers in aircraft Rota-Beam.
  17. #17
    Fire Fighter
    Vintage Collector
    MARSMAN is offline
    Joined June 2011
    LAS VEGAS NV. USA
    Video please!
    I never met a Mars light I did'nt like"
  18. #18
    Just found another lens cage with the extra magnifying lenses.
    Ended up overpaying, but couldn't resist.
  19. #19
    I have an extra one of these!
    Is there a Rota-Beam efficianato out there that has thought of making a hill light out of their Corporal or Model 66?
    Read the above posts for an explanation.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
