Results 1 to 5 of 5
  1. #1
    A-TAD is offline
    Joined May 2010
    South Eastern PA
    Inner Edge bracket, Led Flasher, clear 500 lenses & switchbox
    I am looking for the led flasher from a Whelen Responder or Dominator lightbars,
    or any Whelen flasher for 6 lightheads or maybe a 4 head flasher if I can not find a 6 head flasher.
    2 clear Whelen 500 lenses,
    1 or 2 inexpensive used switchboxes to be used with Streethawk lightbars.
    I am also looking for a cheap/used set of universal brackets to fit a Whelen Inner-Edge, I have the split version.
    Or a set that I can modify to fit it.
    I will take a set of the Universal brackets from the Knock-Off brands.
    Let me know what you have.
    Thanks, A-tad
    "Never bring a control hold to a gunfight"
    "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf"
  2. #2
    fcicars is offline
    Joined May 2010
    Washington State
    I have a couple of Street Thunders (6 switch), a Fed Sig 4 switch and a Whelen PCC S9. $25 each except for the Whelen @$50.
    Quote Originally Posted by A-TAD View Post
    I am looking for 1 or 2 inexpensive used switchboxes to be used with Streethawk lightbars.
    I would like them to have at least 4 switches.
    Thanks, A-tad
  3. #3
    Author of This Thread
    A-TAD is offline
    Joined May 2010
    South Eastern PA
    Updated with led flasher from a Whelen Responder flasher and clear Whelen 500 lenses that I am looking for.
  4. #4
    A-TAD is offline
    Joined May 2010
    South Eastern PA
    Or a set I can modify to fit it.
    Thanks
  5. #5
    A-TAD is offline
    Joined May 2010
    South Eastern PA
    Updated 1st post.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
