Results 1 to 3 of 3
  1. #1
    Author of This Thread
    Senior Member
    Ipuvaepe is online now
    Joined June 2011
    Southeast Pennsylvania
    Signature increases minimum vertical post size
    It places the horizontal line and signature below the bottom of the userinfo block, increasing the minimum vertical size of every post with a signature by more than the equivalent of having 2 professions listed, and thats only single line signatures.
    Not a very high priority problem, but it's kind of annoying.
    Any material protected by copyright in this post is covered by Fair Use, unless otherwise noted.
    This post is provided for informational purposes only and does not constitute legal advice or professional opinion on specific facts. Information provided in this post may not remain current
    or accurate, so recipients should use this post only as a starting point for their own independent research and analysis.
  2. #2
    Technical Administrator
    Jman423 is offline
    Joined September 2010
    Central Florida
    It's a design flaw in the software. While I can fix it, I don't think it is worth my time every time I update the software.
  3. #3
    Senior Member
    Joined June 2011
    Somehow, I figured exactly that... /thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
