Results 1 to 6 of 6
Like Tree4Likes
  • 4 Post By Richard P
Thread: Burnt strobe reflector?
  1. #1
    Author of This Thread
    Senior Member
    Towing
    Volunteer Fire Fighter
    Collector
    Richard P is offline
    Joined May 2010
    Sudbury, On
    I recently picked up a set of 4 linear strobe heads for my excalibur. 2 were a little crispy, the other 2 pretty useable. The charcoaled ones significantly reduced the light output. So instead of buying new reflectors, i touched them up with some aluminum foil tape.
    I cut the tape to a rough shape of the reflector (keeping the backing on the tape), set them in place and did final trimming.
    Once I was happy with the shape, I stuck it on.
    I had some difficulties with the tape sticking in the cold, but most of you wont have that problem. I got some before and after pictures, Unfortunately, my video camera can barely capture the flashes, let alone the intensity of the volcanic ash reflector and the re-finished version, but believe me, the different is night and day! Its well worth the $20 roll of tape and 20 mins of working, even working out int eh cold! my fingers were frozen cock stiff after, but my strobes look new!
    Attached Images Attached Images
  2. #2
    Guru
    Professional Upfitter
    Communications
    Volunteer Fire/EMT
    TritonBoulder47 is offline
    Joined May 2010
    Tunkhannock, PA, USA
    Neat trick Rich... Even off, they looks LOADS better. I'm sure the output is atleast 2-fold+ better...
    - Boulder
    "In the midst of chaos, we find our strength" - Me
    B&B Lighting Solutions B&Bs FaceBook Page Check us out and Like Us!!!
  3. #3
    Junior Member
    Transportation
    Fire/EMT
    Hobbyist
    slash9dotnet is offline
    Joined February 2012
    Conneaut, Ohio
    Nice! Brilliant idea, too! Thank you!
  4. #4
    Ultimate D is offline
    Joined February 2011
    Central Arkansas
    Looks like that worked very well. Great idea.
  5. #5
    Senior Member
    Collector
    Communications
    SireLite is offline
    Joined May 2010
    Merseyside, England, GB
    I've have done this on 500 series halogens and also in the rear lights on my old land rover. It's a great way of bring old lights back to life. Works good on rotators too.
    Jim - SireLite
  6. #6
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Did this to some Whelen strobes, 52 and 500 series. Before/after pics.
    Ryan
    "Blessed are the peacemakers, for they will be called sons of God." Matthew 5:9
Posting Permissions
  • You may not post replies
  • You may not edit your posts
