Results 1 to 9 of 9
  1. #1
    Author of This Thread
    Veteran
    EMT
    Volunteer Fire Fighter
    emtanderson51 is online now
    Joined April 2011
    u.s Massachusetts
    How to turn a 24 or 28 VDC whelen beacon into a 12 VDC one
    The following is a series of posts that detail how to turn a 24 or 28 VDC whelen Rotobeam into a 12 VDC one.
    You only live once so don't screw it up!
  2. #2
    Law Enforcement
    Collector
    50theman is offline
    Joined February 2011
    Virginia
    Quote Originally Posted by rwo978 View Post
    How much did you pay for them?
    I payed the list price like $29, but shipping killed me. It has a 12 volt motor with a resister hooked to it and a 24 volt bulb. To convert it all you do is change the bulb and splice the resistor out.
    5-0
  3. #3
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Quote Originally Posted by 50theman View Post
    Pull out the resistor???
    I have these Whelen motors. They were in a 24 volt Guardian. If I were to take out the black resistors, they'd be converted back to 12 volt??
    Anywho, I'm looking for a blue RB6 dome, so I got intrigued about possibly finding one cheap. But, if it's a crap shoot what I'll get.... I guess I'll bypass that headache.
    Ryan
    "Blessed are the peacemakers, for they will be called sons of God." Matthew 5:9
  4. #4
    Law Enforcement
    Collector
    50theman is offline
    Virginia
    Yes, take the inline diode/resistor out of the red wire and it should convert the motor to 12 volt. The way you can check is for sure is to apply 12 volts to the motor directly.
    5-0
  5. #5
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Thanks Man!! That worked. I'm not up on the 'finer' little parts of electronics (resistors, capacitors, diodes...).
    Ryan
  6. #6
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Sorry for adding all this to the other thread....
    Ryan
  7. #7
  8. #8
    Veteran
    EMT
    Joined April 2011
    u.s Massachusetts
    thanks for the credit as I was baffled when I saw this and didmn't remember starting it....thought maybe I was "sundowning" yesterday lol
  9. #9
    Law Enforcement
    Collector
    50theman is offline
    Virginia
    No problem, I actually found this out by accident. I then contacted a Whelen Technician (friend) and he told me they use 12 volts on all motors but just regulate the voltage by diodes or resistors and the light bulb.
    5-0
Posting Permissions
  • You may not post replies
  • You may not edit your posts
