Results 1 to 12 of 12
  1. #1
    Author of This Thread
    Senior Member
    ChargerLighting is online now
    Joined May 2010
    Berlin, MI, 48002
    Mounting lights into an Edge frame with MX7000 parts
    For a Whelen Edge wrecker bar build I'm doing, I needed to figure out how to add S/T/T lights & keep cost down.
    Instead of paying $17 - $20 ea. for Whelen's version of the 1157 bulb, I decided to use a set of MX7000 S/T/Ts I had laying around.
    The factory MX S/T/T bracket wouldn't fit, so I removed it & happened to grab an MX7000 rotator deck plate bracket.
    It fits great in the Edge's frame & is reversible to mount the lights further in or out (in my case I flipped them inward to keep the STT bulb away from the lens).
    Wasn't sure if anyone had thought of this yet or not, but there are tons of these MX brackets out there & they are pretty ridgid.
    Might be a good solution to those making their own custom Freedoms, 9Ms, 9000s, etc. using their own LEDs.
    I double stacked a couple sho-me LEDs on 1 bracket & they fit.
    Hopefully this will help somebody out.
    Attached Images Attached Images
  2. #2
    Senior Member
    Collector
    MX7K_Collector_2010 is online now
    Joined May 2010
    Elmira, NY
    hmmm interesting use of an MX rotator deck bracket.
    I may have to try that when I get funds to do something with my edge frame with lenses.
    forever on duty............deputy jeffrey alexander R.I.P 06-12-11
  3. #3
    Security
    Hobbyist
    beavercorp is offline
    Joined August 2011
    Nova Scotia, Canada
    It looks like it has potential... and since LEDs generate next-to-no heat, unless they scratch up against the lens, it shouldn't be an issue how close they are, considering as S/T/Ts the shouldn't be on for any length anyway.
  4. #4
    OTFD211 is offline
    Joined May 2010
    Cleveland,Oh
    Charger, I di something similar a few years ago... used the same LED heads but mounted them to ABS plastic sheet. The same style that came in the old 9000 edge
  5. #5
    Volunteer Fire/EMT
    Law Enforcement
    Hobbyist
    ryan81986 is online now
    Joined April 2011
    Boston, MA
    Great idea. Do you have any pictures of the finished product?
  6. #6
    Volunteer Fire/EMT
    NHFD104 is offline
    Joined May 2010
    Raleigh, NC
    FYI - Levolor vertical blinds make great spacers for Edge bars. You just cut them to the length you need and trim about a quarter inch from the edge. I paint them with hammertone aluminum paint to make them look like a part of the bar. Then you just slide it into the grooves. You can get a set of blinds for about $11. It's enough to make spacers for about 20 bars. :-)
  7. #7
    Senior Member
    Joined May 2010
    Berlin, MI, 48002
    Thanks! I made an LED arrowstick w/the brackets but removed them from the bar for now. Its' another one of those back burner things until I get to it - again
    The factory Edge plastics usually work pretty well, but the bars I've been getting lately were from down south & the plastic took a beating (in this case cracking / brittle) via the sun/heat.
  8. #8
    Senior Member
    deputychief301 is online now
    Joined May 2010
    Snow Belt, Michigan
    edge
    Great Idea Mike, Good job
    Jim Rogers
    deputychief301
  9. #9
    Senior Member
    Fire Fighter
    EMT
    Professional Upfitter
    RBRONKEMA GHTFD is offline
    Joined September 2010
    Holland, Michigan
    Thats a wonderful idea.
    Ryan
    GHTF/R
    Payments can be made via paypal, money orders (bank or usps) or cash.
  10. #10
    Law Enforcement
    Communications
    THEFLASH is online now
    Joined May 2010
    ALABAMA
    And if they are too close or you plan on installing a deeper lighthead it appears you could flip the bracket around.
  11. #11
    Junior Member
    Law Enforcement
    Communications
    P1808 is offline
    Joined June 2010
    Florida
    AWSOME
    Its a great idea. i think i have my next project with the parts in the shed.
  12. #12
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    If anyone wants some of these, I have about 15-20.... I think. Didn't count exactly.
    Ryan
    "Blessed are the peacemakers, for they will be called sons of God." Matthew 5:9
Posting Permissions
  • You may not post replies
  • You may not edit your posts
