Page 1 of 2 12 LastLast
Results 1 to 30 of 32
  1. #1
    Author of This Thread
    Newbie
    Spitzen88 is offline
    Joined October 2010
    USA, CT
    Acari Roof Top Mounting System
    Acari 24" DRILL-FREE mounting system.
    I was recently able to get my hands on this mounting system which attaches itself to the back of a pickup truck by unscrewing the brake light on the back of the cab, clamping into that hole, and reinstalling the light on the back of the product. This is going to save me the headache of having to pay the penalties at the end of the lease for drilling holes for a light bar on the top of the cab or having to mount it on a rack frame and still have to drill holes for the wiring. The whole system ended up costing a little over $200 which is a price I am willing to pay to save myself the headache. The best part is that at the end of my lease I can take the whole system off the truck and put it on my new one while keeping the old truck looking good as new.
    On a plus side, the Acari system seems to be able to work in any application whether it be mounting warning or work lights, gps units, antennas or other equipment...
    The only negative aspect I can think of is that this is a new product and is only now becoming available. You might have to search for a while to be able to find it, or do what I did and call one of the reps listed on the web site. I got mine out of Rep Services based out of Parker, Colorado. Check out their website to view pictures and applications.
    http://www.acariproducts.com
  2. #2
  3. #3
    Senior Member
    DaveCN5 is offline
    Joined May 2010
    "The Mitten"
    Re: Acari Roof Top Mounting System
    Quote Originally Posted by JohnMarcson
    Do they offer them in other finishes? I just saw a dodge ram with something similar but it was made of diamond plate.
    Not other material, no. That was mostly likely a custom product. These are quickly catching on for contractors with leased vehicles. Detroit Water just bought dozens of them.
  4. #4
  5. #5
    Newbie
    misparkz is offline
    Joined October 2010
    I assume it's a metal plate right? Is it aluminum? It's 24" long and how wide?
    ** edit**
    Finally got an email back from them and see on there it's available in 24,30, 36" lengths. Anodized aluminum finish.
  6. #6
    Newbie
    Joined October 2010
    USA, CT
    Just wanted to let people know that I just checked out the website again and it has been completely redone with new pictures for each vehicle, videos, etc. so you can get a much better idea of how the product works and what it could be used for. Check it out!
  7. #7
    Senior Member
    DaveCN5 is offline
    Joined May 2010
    "The Mitten"
    Here's one being used with a Low profile antenna and a L31 beacon on a friend's F-150.
  8. #8
    Newbie
    Joined October 2010
    USA, CT
    I just found these pictures on www.plowsite.com. I wasnt sure whether or not the ACARI system would fit if there was already a pro rack/back rack on the truck, but it looks like it fits great!
    Here is the thread for those who may want to check out what they are saying about it over there. Shows a Code 3 mini bar on top.
    http://www.plowsite.com/showthread.php?t=113534
    I sent ACARI an email a week ago and they said they should have their dodge gaskets in the next 4 weeks. Apparently they have pre-sold a lot to dodge ram owners.
    Attached Images Attached Images
  9. #9
    Newbie
    Joined October 2010
    USA, CT
    Just returned from the NTEA Work Truck Show in Indianapolis, IN. I was able to snap a few pictures while I was there (one from the ACARI booth and the others from the Palfinger booth).
    Was quite impressed to see an ACARI mounting platform on two different work trucks in the Palfinger booth! The Palfinger reps said they would be keeping it on their display trucks at upcoming shows. (they told me the next show they are going to, but i cant recall where it is).
  10. #10
    Transportation
    mjw357 is offline
    Joined June 2011
    OHIO
    Just got one of these put on my work truck ('07 Dodge Dakota). As much as I am trying to like it, well, I don't. The problem with it is, the front sits about an inch higher than the rear, makes the lightbar look like it's about to fall off. I may take it back to the installer to see if they can adjust it, if not I may just have them put on some perm mount feet and drill the roof.
  11. #11
    Newbie
    Joined October 2010
    USA, CT
    Quote Originally Posted by mjw357 View Post
    MJW,
    I would be interested to see a picture if that is possible. The directions say that the mount should sit flat and all of the pictures on the website show it being flat, so I would imagine there must have been some sort of problem during installation. Did you try calling the installer? Hopefully you are able to resolve your issue and if you are I would be curious to hear what the problem was. Good luck.
  12. #12
    Senior Member
    Law Enforcement
    Retired1 is online now
    Joined June 2010
    Rural NW Oklahoma
    Mine is on a 2011 Chevrolet Silverado standard cab. It appears to sit flat. My only unhappiness is that the foam seal does not totally seal the Acari to the roof.
    Permanent Texas Peace Officer License - Serving since 1976 - Patrol / Motors / Administration
  13. #13
    Newbie
    ofd149 is offline
    Joined August 2011
    West Haven, ct
    any reports of water leaking into the cab?
  14. #14
    Senior Member
    Law Enforcement
    Joined June 2010
    Rural NW Oklahoma
    Quote Originally Posted by ofd149 View Post
    I can't vouch for it's being watertight. My foam gasket does not appear to completely fill the gap between the mount and the cab.
    I don't know how it will seal in a heavy rain. We are in a continuing drought condition. We have not had any appreciable rain since 2010. I wash my truck by hand and avoid spraying water directly at the Acari mount base.
  15. #15
    Outsider is offline
    Joined May 2010
    CT, MA, NH, VT, MA & RI
    Tilcon in CT just installed their first one (of many I imagine) on a 2006 F-250. So far the reviews from them have been great.
  16. #16
    Newbie
    Joined October 2010
    USA, CT
    I can absolutely vouch for the unit being watertight. I have had my unit on my truck for almost a year now. I removed the top recently to add a work light and wanted to check the lower seal to make sure that after a year it was still watertight... I was actually pretty happy to see that there was no evidence of any water making its way into the mount.
  17. #17
    Vintage Collector
    mixerbd699 is offline
    Joined May 2010
    Wichita Falls/DFW, Tx
    I'm assuming this is useless for a full size lightbar? I like the idea though for mounting my antennas
  18. #18
    Transportation
    First Responder
    twisted_metal is offline
    Joined January 2011
    Toronto ON, Canada
    It wouldnt be useless for a fullsize bar. you could run all your cabling out thru the Acari and use the standard mounts that drill into the door sills. thus saving drilling a hole in the roof.
    Twisted_Metal
  19. #19
    Senior Member
    Law Enforcement
    Joined June 2010
    Rural NW Oklahoma
    Quote Originally Posted by twisted_metal View Post
    I would not expect mine to be able to support the weight of a full size bar nor would it withstand wind loadings / drag of a full size bar.
  20. #20
    First Responder
    Volunteer Fire Fighter
    JazzDad is offline
    Joined August 2011
    South Central Texas
    I was wondering the same thing; about mounting a full size bar on it. It could look a little odd, but if it was stable... Do you think it might cause more twisting from wind drag than the platform was designed for?
  21. #21
    EMT
    whatevah is online now
    Joined May 2010
    Delaware, USA
    Quote Originally Posted by Spitzen88 View Post
    Just a hunch, but you're the production and marketing manager there, aren't you? I saw your posts over on plowsite.com, every post was promoting Acari. It's a cool product, but trying to pretend to be a customer isn't cool, let it stand on its own.
    EMT/Firefighter, occasionally installer of rats nests posing as wiring
  22. #22
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    I would not mount a full bar to something that's only held to the roof by a couple tiny screws where the factory break light screws in.
    Ryan
    "Blessed are the peacemakers, for they will be called sons of God." Matthew 5:9
  23. #23
    Transportation
    mjw357 is offline
    Joined June 2011
    OHIO
    Quote Originally Posted by rwo978 View Post
    That's not how it attaches. It is held in place by a big 'tongue' for lack of a better term, that goes through the 3rd brake light hole and clamps the mount to the roof.
  24. #24
    Senior Member
    Law Enforcement
    Joined June 2010
    Rural NW Oklahoma
    It is easier to understand the mounting system after viewing the installation video.
    Here is the video:
    Category B
  25. #25
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Mmm, OK. My bad. Still don't think I'd stick a full bar up there.
    Ryan
  26. #26
    Senior Member
    Collector
    Communications
    SireLite is offline
    Joined May 2010
    Merseyside, England, GB
    Say's not rust. I see rusty screws.
    Quote Originally Posted by Retired1 View Post
    Jim - SireLite
  27. #27
    Senior Member
    Law Enforcement
    Joined June 2010
    Rural NW Oklahoma
    Under the microscope
    Quote Originally Posted by SireLite View Post
    Well, I prefer to refer to the 8 high-tech fasteners (AKA: screws) as 'dual tone' = black & brown.
    Yes, they are rusty.
    Disappointing, as this Acari is less than 6 months old, never been in a car wash &, is operated in a dry climate (only 3" of rain since last November). I thought they were black anodized, but apparently not. Looks like some black touch-up pant is needed to enhance their appearance until I can replace them.
    Even though they will not become so rusted as to become structurally unsound in my lifetime, they are unsightly. When I get the spare time to do so, I will see about replacing them with stainless steel (SS) fasteners. IMHO, SS fasteners should have been used in the original manufacturing process.
  28. #28
    Guru
    Law Enforcement
    Hobbyist
    rwo978 is offline
    Joined May 2010
    North Dakota, USA
    Agreed on the stainless steel.
    Ryan
  29. #29
    Outsider is offline
    Joined May 2010
    The fasteners have recently been updated to annodized ones that won't rust. DO NOT use stainless screws on aluminum! The folks at Acari Engineering will replace your rusted screws at no charge with the new ones if you contact them and ask.
  30. #30
    Fire/EMT
    Professional Upfitter
    factorone33 is offline
    Joined June 2010
    Overland Park, KS
    Quote Originally Posted by Outsider View Post
    We're a dealer for Acari and we've been having to replace some screw sets because of this. I couldn't believe they didn't think about that to begin with.
    We DO have a 30" version of the product in our office here with a 44" Justice bar on it, and it looked great on the back of one of our trucks last month.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
