Results 1 to 11 of 11
  1. #1
    Author of This Thread
    firefighter_2000 is offline
    Joined May 2010
    Bauxite Arkansas
    Swissphone RE729 Pager
    Bought a Swissphone RE729 pager last year and so far it has performed very well. The pager is small but seems to be well built and very rugged. Before I got the leather case for my belt, it was dropped a couple of times and had no problems. The edge has some sort of rubber liner around it, seems to cushion it from drops etc. It is a bit tricky to get used to as far as the buttons and menu goes, but once you figure it out, there's nothing to it. It is very customizable, even going so far as to make it one button operation, like the old keynote pagers. It runs on a single AA alkaline or regchargable battery and the pager & charger recognize this and even if you put it in the charger with an alkaline battery, it will not attempt to charge it. It has up to 50 addresses available as well. I work two jobs, as well as my volunteer department and Im able to change to whichever location Im at on that particular day: Fire station 1, 2, 3, or 4... Medic 1, 2, 3, or 4 when Im at the ambulance, and finally my volunteer department. I can litterally wear this pager 24/7 and always be able to be paged. This pager has proven VERY useful in that area. The voice storage is I believe 4 or 8 minutes long, and it will generally hold a weeks worth of calls in the storage. I can hit playback, and it will go and go and go. So far the ONLY problem I've had is the charger cord. Moving from fire station to station, ambulance station to ambulance station, and home the cord had been wound up so many times that the end broke. I've solved that problem with two chargers. One for the house and one for the fire house. Price is VERY comparable to the Minitor 5's and I believe it to be a superior product. If anyone has any questions, or would like additional pics, just let me know.
    Thanks
    Craig
    http://www.swissphonena.com/
    Member of the ORIGINAL RAM4 elightbars.org
    AND an experienced provider of useless information.
  2. #2
    Joined May 2010
    Bauxite Arkansas
    Re: Swissphone RE729 Pager
    Still working GREAT. Love the capability to change channels depending on where Im at for the day. Have had ZERO problems so far. Be sure & get the leather case. Protects the pager very well. We are on the 155 range.
    Craig
  3. #3
    Veteran
    Fire Fighter
    grfd711 is offline
    Joined June 2010
    Sherwood, AR
    As I know nothing of these pagers, does it have a vibrate option? How loud is it when it beeps? McAlmont is looking to get away from the Motorola 5s due to high failure rate. Also, are these pagers compliant with the 2013 rebanding coming up?
  4. #4
    Joined May 2010
    Bauxite Arkansas
    They have several options actually. Vibrate only, Tone Only, tone & vibrate, silent. Pretty loud and vibrates well enought to know its there. Call Lisa at Bates Sales & Service in Mt. Ida. They can actually program one up for you and let you demo it for a couple of weeks to see how you like it. And yes it is 2013 compliant.
    Craig
  5. #5
    You said it has menus in it so Is it able to be field programmable.
  6. #6
    Communications
    Volunteer Fire/EMT
    Emergency Management
    WhiteLite03 is offline
    Joined October 2010
    Middle Tennessee
    I demo'd one of these earlier this year for a month. My department uses Minitor 4 & 5. I found that much like the OP said, it is very easy to use once you figure it out, has a few more buttons than the Moto products we're used to, but I liked the fact that it has a display and showed me what time the call was paged, and how long it had been. Very helpful if you're in another room and you walk in to notice there has been a call, but don't know if you still need to go. The volume, IMO, isn't quite as loud as the Minitor, but is adequate for getting your attention. The vibrate and silent features are great also. All of the alerting options you can program via the buttons on the pager, no need to have a programming cradle and software, however you can buy those from swissfone also if you want to add more frequencies, etc. Overall I was very impressed with the pager, but I had to return it as I didn't have the money to purchase it at the time.
    911 Dispatch
    Vol. Firefighter
    NREMT-B
    Emergency equipment installer (on the side)
    "Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety." Benjamin Franklin 1759
  7. #7
    Senior Member
    ParkPiggy is offline
    Joined May 2010
    Northeast Ohio
    What type of price range are these at?
  8. #8
    Newbie
    fireman108 is offline
    Joined June 2011
    United States, Indiana
    RE: Swissphone RE729
    I am curious as to how you think the paging volume compares to the Minitor5? Our department is looking at new pagers and have considered the Swissphone but we want something that will wake our guys up in the middle of the night since we are a volunteer department. What are your thoughts? Thanks!
  9. #9
    WNYEVS is online now
    Joined May 2010
    Brockport NY
    I demo'd one of these last year. They are freaking crazy loud!
    There is no way you can sleep through it!
  10. #10
    Junior Member
    35superwacker1 is offline
    Joined January 2012
    Pennsylvania
    Gotta be careful with them, my depts tones would program into it yet the pager never tripped. Conclusion was it was out of range. Our tone are 794 and 347.
  11. #11
    Newbie
    conman1288 is offline
    Joined February 2011
    NY
    Do these work with VHF low?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
