Results 1 to 13 of 13
  1. #1
    Author of This Thread
    amccullers is online now
    Joined May 2010
    Wetumpka, Alabama
    1999 Chevy Tahoe
    This is my work vehicle for the city of Wetumpka. And yes it is a '99 work truck version tahoe. The PD used it before the FD got it and it may have been owned by the state before that.
    Front
    2 dual R/W talons
    HAW strobes in the turn signals
    Side
    8inch microman 3 watt bars R/R each side
    Rear
    20inch microman 3 watt R/A/R/A/R
    Console
    Kenwood 7160 vhf
    whelen siren w/SA 314 speaker
    SW300 switch box
    Fuse block
    whelen ulf44 for the microman bars
    Will be adding grille guard this weekend, and ordering some more microman bars for front and side coverage on guard. Will also move my siren speaker to the guard, it is in the engine comp. and it is loud inside the cab. Would the speakers be better on top or bottom of the guard cross bar?
    Video
  2. #2
    Joined May 2010
    Wetumpka, Alabama
    For the lights on the guard, I already have a whelen D2 and 2 red pimp pods or should I order the microman bars?
  3. #3
    Mr911 is offline
    Joined June 2010
    Northeastern Pennsylvania
    Personally, it all comes down to budget. I say use what you have...you can always upgrade later.
  4. #4
    It doesn't look half bad, especially bodywise... Shape is certainly passé, but it still looks pretty good from here, especially given the harsh Pennsylvania winters and the PD/FD/SP and whatever else hard use and abuse...
    "Professionally Anonymous"
  5. #5
    Joined May 2010
    Wetumpka, Alabama
    Yea she is in pretty good shape. The clear coat is comming off in spots on the hood, and the grill couyld be repainted, but the biggest problem is that the AM/FM radio antenna is bad so I don't have any tunes to listen to. LOL
    I think I will install the lights I already have for now.
  6. #6
    Veteran
    VolEms is offline
    Joined May 2010
    NY, USA
    I would put both talons on the same flashpattern and add a headlight flasher.
  7. #7
    Joined May 2010
    Wetumpka, Alabama
    One talon is passive and the other is ballast, so that is the closest flash pattern.
  8. #8
    Joined May 2010
    Wetumpka, Alabama
    Added the guard, speakers, and lights.
  9. #9
    Joined May 2010
    Wetumpka, Alabama
    Changing up the vehicle a little bit. I will be adding a microman TA in place of the 20" bar. Adding 2 8" bars to the lower part of the rear window and removing the dominator on grill guard and putting in a 8" microman bar. I have bought a cencom red to control everything and I built a center console.
    Here are the first pics of the console. I still have some pieces to get and more wood work.
  10. #10
    Senior Member
    Fire Fighter
    EMT
    Police/EMS
    Luismariadarlene is online now
    Joined May 2010
    Edinburg, Texas RGV
    Quote Originally Posted by amccullers View Post
    looking good what is the brand of that fusing system next to the cencom
  11. #11
    Joined May 2010
    Wetumpka, Alabama
    Quote Originally Posted by Luismariadarlene View Post
    It is a blue sea.
  12. #12
    Junior Member
    Case-IH95 is offline
    Joined February 2012
    Wisconsin
    What is that connected to your 4x4 lever?
  13. #13
    Joined May 2010
    Wetumpka, Alabama
    Quote Originally Posted by Case-IH95 View Post
    Its not connected to it, it just looks like it. It is the channel lock rescue tool hanging from the cup holder.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
