Hey guys. Still figuring out what i want to do to her. here is my current set up and was all installed by me. I'm a FF/EMT in NH so we get red/white/amber lights.
from the front
-i have the whelen projector series speaker mounted directly to the push bar.
-Also have 2 LINZ6's split red/white on the L-brackets.--> thinking of 400 series split red/white which is the reason they are vertical.
-whelen dual avenger red/white on a headliner mount.-->thinking of getting the passenger side inner edge and moving the avenger to the center of the winshield low.
-Also a pair of the mirror beams driver's side red. Passengers side white.
From the side
-side of the push bar one on each side i have the M2's red
-rear passengers door both sides TIR3's red
From the rear
-Whelen Dominator TA Plus with ends flashing red/red and center bar amber with TA function
-Whelen LINZ6's split red/amber on the liscence plate.
interior
-Havis charger console.
-I have the Whelen SLS295A6 siren control box with switches. Mainly use the three slide switch so i have a lot of empty buttons.
-Whelen TA control head with power on off to the SLS295A6 to cut down on run time of the unit
Any suggestions on what i should add/take away? to much/not enough? looking for some input on my ideas about the inner edge and 400 series as well. thanks
100_0959.jpg100_0960.jpg100_0961.jpg100_0962.jpg100_0963.jpg100_0964.jpg100_0965.jpg100_0966.jpg100_0967.jpg100_0968.jpg
35Likes
LinkBack URL
About LinkBacks
