Results 1 to 11 of 11
Like Tree5Likes
  • 1 Post By SNOW SYSTEMS
  • 3 Post By TheGatekeeper
  • 1 Post By TritonBoulder47
Thread: HALO led kit installed in f250
  1. #1
    Author of This Thread
    SNOW SYSTEMS is offline
    Joined September 2010
    Illinois
    Worked out great. Install was simple.
    nerdly_dood likes this.
  2. #2
    Vertical video syndrome ?
    "We make the weather"
  3. #3
    Illinois
    Quote Originally Posted by TheGatekeeper View Post
    Is there something you can't see???its an iPhone camera
  4. #4
    Veteran
    Military
    nerdly_dood is offline
    Joined June 2010
    California
    Hold the phone sideways and you'll get a video that doesn't look awful.
    Fewer, slower, bigger. (Usually.) When putting warning lights on a vehicle, ask yourself why exactly you're putting that particular light in that particular location: Why are you using that light? What advantage does it have over other lights? Why that particular location?
    If you're doing it because it looks cool, it's probably a bad idea. Unless an AeroTwinsonic is involved, in which case it's automatically both cool and an excellent idea.
  5. #5
    Senior Member
    Fire/EMT
    Law Enforcement
    NFD-102 is online now
    Joined August 2011
    Connecticut
    you should sync those up...maybe criss-cross.
  6. #6
    nybucketman is offline
    Joined May 2010
    Harrisburg, PA
    I also just installed front and rear halo kits in my super duty. They were easier than I expected too. Unfortunately, I don't believe they can be synced with other light heads.
  7. #7
    Illinois
    Quote Originally Posted by nybucketman View Post
    True. Have fedsig LEDs in the reverse. Actually removed the stock reverse bulb to utilize reflector with the led. Have 500 integrated in a ranch hand bumper now too.
  8. #8
    Joined May 2010
    Harrisburg, PA
    How did you get the led hide-a-ways to steady burn when reverse is selected and flash on a switch? Is that a function available with the fed sig hide-a-ways? I don't believe the strobes n more hide-a-ways or whelen vertexes have the dual position inputs
  9. #9
    Junior Member
    philter74 is offline
    Joined May 2010
    Nyack, NY
    The Whelen HALO system replaces the factory brake light bulbs and uses a central module to operate the standard park/turn/tail functions as well as a warning option.
    http://www.whelen.com/pb/Automotive/...alo_Series.pdf
    Quote Originally Posted by NFD-102
    There is no sync function available on the HALO system.
  10. #10
    Joined May 2010
    Harrisburg, PA
    I was referring to snow systems led reverse lights, not the halo kit. I also have the halo kit. In snow systems video, you can see the federal signal led hide-a-ways in his reverse lights come on steady burn while in reverse, then flash in a warning mode after flipping a switch.
  11. #11
    Guru
    Professional Upfitter
    Communications
    Volunteer Fire/EMT
    TritonBoulder47 is online now
    Joined May 2010
    Factoryville, PA, USA
    He probably used a STT flasher of a sort, like the one from Sho-Me...
    http://www.able2products.com/pdfs/11...structions.pdf
    Storm4200 likes this.
    - Boulder
    "In the midst of chaos, we find our strength" - Me
    B&B Lighting Solutions B&Bs FaceBook Page Check us out and Like Us!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
