Page 1 of 2 12 LastLast
Results 1 to 30 of 32
Like Tree16Likes
Thread: "HillBilly Deluxe" F450 Wrecker. Need lighting ideas. help!
  1. #1
    Author of This Thread
    Senior Member
    Towing
    Volunteer Fire Fighter
    Collector
    Richard P is offline
    Joined May 2010
    Sudbury, On
    Well, Most of you may remember my wrecker from a few years back. About 2 years ago, I pulled it from service to bring it to a shop for its annual inspection and a coat of chameleon purple/copper gold paint and a park brake. well, the mechanic was a douche, said engine was shot, reason why it had no balls. He took the cab off to get the engine out, removed the towbody for sandblasting and prep it for paint. I didnt know there was a warrant for his arrest, he skipped town, left my truck for months in a feild 40 mins out of town. THe original chassis and cab was a 2007, I bought a 2001 parts truck (interior panels, tires, rims, engine parts for my f250 gasser) and the engine is from a 2003 bus I picked up, 444CuIn diesel.
    So I took a few trips and brought it back and been rebuilding for a few years when I can, it was totally stripped. I got it all back together, had to build an engine (did it myself) installed it, set cab on and my friend helped me set the tow body on and fasten it down, she was the only one who really helped. I got it running, but it was slow and no balls still. Turns out my new turbo charger was the wrong one, didnt build boost. And to add insult to injury, the old engine was fine, the turbo was shot. I rebuilt my old one with the internals of the new one and shes fine.
    For lighting right now, I got my custom built 58" MX7000. has 4 rotators, and a butt load of mirrors to the rear, i think 12 or so, so its one long rolling flash! no square in to the rear is un lit! you dont need lots of lights if you know how to place mirrors! It also has sweeps with amber to the front of them (primary for hauling) which also come on with the 2 rear amber flashers. It has 6 takedown lights and 2 running lights to the front, 4 rear work lights, alleys and STT lights.
    I also have 2 fed sig PAR36 flashers, impaxx on the side of the push bumper and Ill add TIR3s to the grill later.
    I have a SWS 6 button switch panel and a whelen control center mounted over head, the wires run through ther headliner and A pillar.
    I also totally rewired the trucks factory wiring system. I removed the wiring harness totally for headlights, tail lights, signals park lights, brake lights and reverse lights. I ran all new 7 wire cable for everything. There is now separate brake lights from the signals. THe 7 wire powers left, right, brake, tail, reverse, and warning/aux light aswell as ground. it runs from the rear, to under teh cab under driver seat to a junction box, which splits to the front and up into the cab. Once it reaches the inside of the cab, it goes to a terminal block (out of a turbo beam bar) on the dashboard just next to the steering wheel, where it can easily be accessed for testing and adding additional lights. the wires then run into the steering column to the signal light arm (i removed the factory harness from the arm) and also to the brake lights and power output from the headlight switch. I also have a constant power and ground on the block for testing. both left and right side have their own in line flasher.
    Im going to get mor detailed pictures from underneath, but my back is acting up, cant get under it right now. Ive been working at this steady for one week, my first time really touching it in almost 2 years. As of yesterday, Im at a stand still until I get cash, so the past 2 days are just accessories such as my window sticker, dixieland horn, interior trim etc, dont want to waste a day because of no cash. Things are tight, lots of personal problems im trying to work out, im off work for a bit. just trying to stay out of the liquor, keep busy and save what little cash I got coming in.
    Link to the full album on facebook:
    Facebook
    Attached Images Attached Images
    kadetklapp, Retired1 and badge22 like this.
    -Richs Towing
    -Northern Lights PSE
  2. #2
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    Videos
    heres a lighting demo video
    Towtruck Install - YouTube
    and for shits and giggles, the horn! Ive been a dukes fan since I can remember, Ive seen all 144 episodes, been to dukes fest etc.
    Tow truck horn install - YouTube
    -Richs Towing
  3. #3
    Senior Member
    Hobbyist
    strobecrazy is offline
    Joined April 2011
    GA,ATL
    Love the surgebar!
  4. #4
    Senior Member
    MESDA6 is offline
    Joined June 2010
    Central IL
    It would not be complete without the horns!
  5. #5
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    the surbar is just a multi plug lol. All my vehicles are equipped with a 120-12vtransformer so I can plug them in and run the radio, lights etc off 120v. there was an inverter inside to plug things in like shop vacs, laptops,, etc. and HD inverter from big rigs, can power a small fridge off the truck!
    Heres pics of my terminal blocks under the truck and inside. The black 7 wire cable runs the rear and front of the truck, the grey cable goes up into the cab where I have a power distribution terminal. The top terminal is a constant power, for testing and accessories, the bottom is a ground.
    R------ +
    Y------ +left signal
    G------ +Right signal
    B------ +park lamps
    R------ +brake lamps
    B------ + from switchpanel -> rear flashers
    W----- -
    For some reason, after altering this system, My power windows no longer work. They worked right after it, but after a bit of time, they stopped, aswell as the OEM horn, and when I hit the brakes, the voltage guage drops, but the actual battery voltage does not. Im going to have to go through fuses. I never had any arcing or any issues with anything.
    -Richs Towing
  6. #6
    Veteran
    kitn1mcc is offline
    Joined May 2010
    Old lyme ct
    getting there
    Dub step
  7. #7
    Rusted413 is offline
    Joined May 2010
    Blacksburg, VA
    I usually don't get too jazzed up about wreckers, but I gotta say I love your passion and know-how. Great work building your vehicle back up and getting it cleaned up and looking how you like it. Tip of the hat for sure. Keep us posted!
  8. #8
    Veteran
    Military
    Law Enforcement
    BigWil is offline
    Joined May 2010
    NL
    I assume you are going to change the lenses to amber on the lightbar before the truck goes into service?
    Some people couldn't get it together even if it came in a combo!
  9. #9
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    THeres red and amber filters under the red lenses, I just borrowed the red lenses since my clears are MIA. The bar is totally red to the rear with the exception of the 2 amber rear flashers. the outter rotators have an amber half filter to the front.
    -Richs Towing
  10. #10
    Volunteer Fire/EMT
    Communications
    Collector
    Bill Boyd is offline
    Joined July 2010
    Avon, NY
    Are you still going to paint it as you originally planned?
  11. #11
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    Not Too sure, Might give it another black coat and do some red stripes.
    -Richs Towing
  12. #12
    Fire Fighter
    EMT
    Hazmat
    GTRider245 is offline
    Joined June 2010
    Georgia
    And what is this thing supposed to be used for?
  13. #13
    Guru
    Professional Upfitter
    Communications
    Volunteer Fire/EMT
    TritonBoulder47 is offline
    Joined May 2010
    Factoryville, PA, USA
    Quote Originally Posted by GTRider245 View Post
    Hauling Potatoes...
    It's a Tow Truck... One would assume that it will be used to tow vehicles...
  14. #14
    Veteran
    Military
    nerdly_dood is offline
    Joined June 2010
    California
    I was impressed until I saw that you've got red lights on a tow truck.
    Fewer, slower, bigger. (Usually.) When putting warning lights on a vehicle, ask yourself why exactly you're putting that particular light in that particular location: Why are you using that light? What advantage does it have over other lights? Why that particular location?
    If you're doing it because it looks cool, it's probably a bad idea. Unless an AeroTwinsonic is involved, in which case it's automatically both cool and an excellent idea.
  15. #15
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    Quote Originally Posted by nerdly_dood View Post
    you obviously havent read that the clear outter domes are smashed, and the other on another bar, reds are to prevent water from destroying the light. it is although red to the rear. Emergency ( police contracted per officer) wreckers (not flatbeds) can run red 360*, i run only to the rear. You have to remember, we often sit in the middle of 100 km/h highways cleaning up wrecks, we dont need to be confused with a construction pick up laying out cones! plus im VFF, so often at wrecks not hauling vehicles
    -Richs Towing
  16. #16
    Veteran
    Military
    Law Enforcement
    BigWil is offline
    Joined May 2010
    NL
    Quote Originally Posted by Richard P View Post
    I'm very familiar with the Ontario Highway Traffic Act, and I don't recall seeing anywhere that police contracted tow trucks could run red at all, much less 360*. I moved out of Ontario a few years ago, so things may have changed. Do you have a link to the act/regulation that authorizes it?
  17. #17
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    I have no idea where to find that, An officer at the police HQ looked it up on a computer and printed me a sheet a year or 2 ago of the HTA. This was for police contracted tows, up north aint like the GTA, its not all freelance chasers first come first get. We all bid for police tows, I was the lowest, but only one wrecker, never put my tilt in service. Im number 2 on the list though of 3.
    -Richs Towing
  18. #18
    Veteran
    Snow Removal
    Hobbyist
    Collector
    7d9_z28 is offline
    Joined March 2012
    Michigan
    When I saw your name, and a wrecker thread, I was hoping to see a wrecker with some form of Turbobeam on it!
    WARNING: I receive and read through Galls catalogs. Therefore, I am an expert in emergency services equipment.
  19. #19
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    Quote Originally Posted by 7d9_z28 View Post
    It used to have a 69" turboflash. 16 strobes, TDs, work lights and STT lights. but it didnt leave room for alleys or any other special lights, so I rebuilt my 58" MX7000
    -Richs Towing
  20. #20
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    Ok, I got the lighting system (signals, brake, park) is all buttoned up. I installed my signal light flasher inline to the power feeding the signal light arm/switch. THe turn signals and park lights in the MX are hooked up, Cant get brake lights though, I added diodes to prevent the signals from back feeding the brake lights, but nothing to prevent the signals from backfeeding brake lights, Im stumpped so Im leaving brake lights out of there. I got a relay in the under cab junction box off the reverse light wire and my constant power to trigger the upper 4 work lights. Also, the back up beeper is grounded in the cab to a dash switch so it can be killed (late night runs, pulling in my driveway or leaving someone elses, dont want to wake people). When the truck is in reverse, it also triggers the rear PAR36 flashers.
    Since I most likely wont be adding TIR3s or lights to the grill, I added HAWs to the front signals. Im unhappy with my placement, sould have put them in front of the bulb on the bottom. I mounted the PS on the floor in the front.
    Also finished the painting, popped out some dents, please excuse my hoard in the background, I got junk everywhere!
    -Richs Towing
  21. #21
    Veteran
    kitn1mcc is offline
    Joined May 2010
    Old lyme ct
    dovy6 likes this.
    Dub step
  22. #22
    Senior Member
    Collector
    Vintage Collector
    HFD eng1ine is offline
    Joined July 2010
    Essex County. MA
    The turbos in 7.3's are SO HARD TO GET TO.
    W6---343FDNY---C9
    NEVER FORGET
    --^v--^v--^v--^v--
  23. #23
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    Ok folks, Its down to the fun stuff! all the major things pertaining to the trucks performance, safety and mechanical have been taken care of. now onto what we are all on this board for!
    So far the truck has the 4 rotator mx7000, white and amber to the front, all red to the rear with 2 amber flashers. I got 2 amber fed sig par36 flashers under the rear bumper, impaxx o the side of the push bumper and a pair of HAWs in the front signals.
    lights i have laying around:
    2 amber LIN3s, 1 TIR3, 2 amber dual talons, so far theyre mounted to the bottom of a slickstik, red sweeps and 5 lamp TA. I got an AA viper S2 and i think thats about it.
    I was thinking the LIN3s mounted on the rear sides of the towbody to cover as side warning just like the Impaxx on the pushbar.
    I was maybe thinking the slickstick in the rear window, either with or without the talons. maybe talons in the side windows or get another TIR3 and pu them in the side window? or leave them lightless.
    Put my viper S2 back in the windsheild? or a talon? or both talon mouted each side of the the roof mounted switches.
    I feel i got plenty of front warning with the lightbar and HAWs, definately covered if i use a windsheild light. I think the LIN3s on the rear side would work well. I had a suggestion of the LIN 3s on the rear upper of the headache rack, but I got the 2 amber LED flashers in the MX and under the bumper, Im covered high and low.
    -Richs Towing
  24. #24
    Senior Member
    WS224 is offline
    Joined November 2010
    West Tennessee
    Paint the wheels.
  25. #25
    Veteran
    Snow Removal
    Hobbyist
    Collector
    7d9_z28 is offline
    Joined March 2012
    Michigan
    Quote Originally Posted by WS224 View Post
    Paint the wheels.
    Put LINZ6 on the wheels.
  26. #26
    Junior Member
    Fire Fighter
    JMcManus is offline
    Joined July 2012
    New York
    1st, What on Gods green earth do you need 3 head units/cd players for? 1 Just wasnt good enough?
    2nd, Is this really a recovery/accident vehicle? Do you actually preform recoveries with this single line boom/wrecker body? Is a single line recovery acceptable practice in Canada?
    3rd, Is that a ratchet strap I see holding the wheel lift up??
  27. #27
    Moderator
    Emergency Management
    Law Enforcement
    Military
    unlisted is offline
    Joined May 2010
    Canada
    Quote Originally Posted by JMcManus View Post
    He doesn't call it the "hillbilly deluxe" for nothing..
    An annoyance online since original BBS days- early 90's. Damn I miss modem tones... but not 14.4 kbit/s.
    You know what the chain of command is? It's the chain I'm going to get and beat you with until you understand who's in command here.... (best quote ever!)
    I collect green lighting. Let me know what you have!
  28. #28
    Senior Member
    Towing
    Collector
    Joined May 2010
    Sudbury, On
    The 2 head unit is a DVD player and above is the screen. The stereo is located below. that was explained in the very first post or two when someone else asked that.
    Secondly, only 3 or 5 ton wreckers have dual lines around here. And Ive only seen one dual line wrecker in this city, theres not much more advantages. Never in my career with this have I said " i really could uses a twin line" nor Have I ever said " I wish I had a flatbed", figure I get that one out of the way too before you asked anything like " does anyone practice with wreckers anymore in canada?" lol I had a tilt, never used it, wasnt worth my purchase. Id rather use my 15,000 lbs tandem float trailer with my wrecker.
    Lastly, as Ive been saying, and as you probably should have read earlier in the thread, I did not have sufficient hydraulic oil in my truck, and I didnt have time to get more, so it had air in the lines and would creep down. this truck is a scratch build, it isnt perfect yet.
    And WS224, The wheels have been soda blasted and painted with a duplicolor "chrome" paint, its brightened them up a bit.
    Not in the picture is 2 100w par36 spot beams. These shine to the end of the road! they practically burn a hole in the neighbors garage door! they are brighter than any scientifically designed driving/off road light and with the rubber housing, theyre $20 each
    And the blacklight/ LED instroment cluster is done! so aside from the 4 pushbar lights and STT lights in the MX7000, all OEM running and truck lights are LED/HID. only thing halo/incan is the MX7000, nothing else!
    And I think ive decided for sure on the LIN3s on the rear sides of the truck. unsure of interior, if any.
    -Richs Towing
  29. #29
    Hobbyist
    Collector
    Vintage Collector
    dg0223 is offline
    Joined February 2011
    USA/Texas
    I know you mentioned the red domes on your MX were just so your lightbar won't get damaged, but it seems that you've squared away almost all the other issues your truck was having, so I'm curious why you haven't replaced the domes yet. Do you drive your truck around with the red domes on the lightbar?
    I'm sure there are several members on here who would be able to get you a reasonably priced pair of amber or clear domes for your lightbar.
    Also, and forgive my criticism; I am not saying this to be rude...
    If you're using your truck in any official capacity, I would rethink the use of the large "Hillbilly Deluxe" decal on your windshield. It doesn't look very professional.
    Andy L. likes this.
    Beware the LASER JetSonic. It will mess you up!
  30. #30
    EMT
    Collector
    Hobbyist
    IshyFlynn is offline
    Joined February 2012
    Maine
    Quote Originally Posted by dg0223 View Post
    If you're using your truck in any official capacity, I would rethink the use of the large "Hillbilly Deluxe" decal on your windshield. It doesn't look terribly professional.
    Don't get me wrong, I get you... I totally get how you could say putting "Hillbilly Deluxe" is unprofessional...
    But you know, I think it could be a positive promotional gimmick... I mean, it does stick with you, doesn't it?
    The statements I make here do not necessarily reflect the views of any organizations, services or state licensing bureaus I am affiliated with.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
