Results 1 to 8 of 8
  1. #1
    Author of This Thread
    Newbie
    BlinkyBlueLight is offline
    Joined February 2011
    Illinois
    Re-wiring project for POV.
    So, about four years ago, I inherited a Cavalier as my car when the wife got the new car. I planned on buying a new car later that year, but this car gets pretty good mileage, so we ended up keeping it and plan to run it into the ground. There is something to be said about proper maintenance and upkeep.
    I had wired up a "temporary" install of my emergency lights (Assistant Chief for small VFD), and my VHF radio. I later added a scanner, but it too is kind of "temporarily" installed. I decided over the weekend that I wanted to re-wire everything that would:
    1. Make it easier to remove, upgrade, or repair equipment as needed.
    2. Bring wiring up to standards, mark wiring better and conceal/run the loom better.
    3. And make it easy to just pull the install out and plop it into a new vehicle when that time comes.
    So, here is goes. Please offer advice or feed back , as I don't do this very often and would love to hear advice.
    Here are the parts for the power box:
    Junction box from Lowes (8x8x6)
    Circuit junction block (x6)
    Terminal strip x 8
    Two relays.
    Here's the parts laid out:
    Next, I installed the relays off to the side.
    Next, I put the circuit block in. Then I realized I put it in backwards. Oops.
    Here's everything mounted up and holes for power lines drilled. Gotta stop at the store and get a blue spade connectors, since I'm out!
    More to come!
  2. #2
    JCLG316 is online now
    Joined September 2010
    Reading, Pa
    Like the circurt breaker idea but most companies including Whelen recommend that you don't use them for some reason. Just a heads up thats why I use fuses.
  3. #3
    Newbie
    Illinois
    Quote Originally Posted by JCLG316 View Post
    Apologies, should have been circuit block, not breaker. It's got fuses.
  4. #4
    Law Enforcement
    Volunteer Fire Fighter
    5309 is offline
    Joined January 2012
    Central, Florida
    pictures of project car would be great!
  5. #5
    Volunteer Fire/EMT
    Hobbyist
    Bfat567 is offline
    Hudson Valley NY
    Looking forward to this one. I too have a inherited cavalier that im just gonna run into the ground.
  6. #6
    FFRNDAN` is offline
    Joined May 2010
    Edinburg, OH
    I'm sure you know this already, but don't forget the zip ties and a couple grommets for the holes you just made. I'm completing a re-wire myself right now. Looks good so far!
  7. #7
    Senior Member
    Volunteer Fire/EMT
    Professional Upfitter
    theroofable is online now
    Joined May 2010
    New Jersey
    What do you have the relays doing?
  8. #8
    Senior Member
    Fire Fighter
    EMT
    Police/EMS
    Luismariadarlene is offline
    Joined May 2010
    Edinburg, Texas RGV
    pics of the car please
Posting Permissions
  • You may not post replies
  • You may not edit your posts
