Results 1 to 12 of 12
Like Tree7Likes
  • 3 Post By Ipuvaepe
  • 1 Post By strobecrazy
  • 2 Post By Ipuvaepe
  • 1 Post By CenTexPSE
Thread: Not necessarily split fail, but definitely needs help...
  1. #1
    Author of This Thread
    Veteran
    Emergency Management
    Communications
    Hobbyist
    lafd55 is offline
    Joined May 2010
    New York, USA
    CSX Police 2003 Tahoe. The grille lights are not split, but definitely need a flash pattern change...
    "Drew"
    OEM
    Fire/EMS
    Hobbyist
  2. #2
    zsiya is offline
    Joined May 2010
    AL
    Probably already been replaced-the tag expired in '09. Having dealt with CSX in the past, the pattern does not surprise me.
  3. #3
    Senior Member
    Ipuvaepe is offline
    Joined June 2011
    Southeast Pennsylvania
    The grille lights are ABSOLUTELY split fail. That's a textbook example of Type A split fail.
    Any material protected by copyright in this post is covered by Fair Use, unless otherwise noted.
    This post is provided for informational purposes only and does not constitute legal advice or professional opinion on specific facts. Information provided in this post may not remain current
    or accurate, so recipients should use this post only as a starting point for their own independent research and analysis.
  4. #4
    What pattern ?
    "We make the weather"
  5. #5
    Veteran
    Communications
    Hobbyist
    lafd55 is offline
    Joined May 2010
    New York, USA
    Slow would be nice if they were split color heads, but being single color they should be faster and synced.
    "Drew"
    OEM
    Fire/EMS
    Hobbyist
  6. #6
    JCLG316 is offline
    Joined September 2010
    Reading, Pa
    Any one knows what light stick that is in the rear with the Red and Blue then Amber?
  7. #7
    Senior Member
    Hobbyist
    strobecrazy is offline
    Joined April 2011
    GA,ATL
    Quote Originally Posted by JCLG316 View Post
    I didn't see no amber. I think its just a shitty pattern making it look different.
    calebsheltonmed23 likes this.
  8. #8
    JCLG316 is offline
    Reading, Pa
    maybe the purple phase was getting to me. but its still a nice stick and i would be happy to have it in my truck. lol
  9. #9
    Senior Member
    Ipuvaepe is offline
    Joined June 2011
    There is absolutely no good reason to have split head lights of the same color (except for having half steady burn and half flash, and that's only if there is no low power mode), and depending on the laws of your state they may not even count as emergency lighting (for example, if your state requires a red or blue flashing light be visible from 500ft guess what, they aren't!). The best only thing for them to do without replacing the lights would be to alternate all of the red with all of the blue.
    nerdly_dood and waldalm like this.
  10. #10
    Senior Member
    Professional Upfitter
    Volunteer Fire Fighter
    CenTexPSE is offline
    Joined May 2010
    Covington, TX
    If split fail was a crime, this one would be a Class A Felony. For 1, there is no reason to split a lighthead that small. Just not enough output. For 2, when you split a lighthead of the same color, from a distance of more than 150 feet you get a steady burn effect. You cant tell that they are alternating.
    waldalm likes this.
    Matt
    CenTexPSE
    N. Central Texas Dealer for Sound Off Signal, Code 3, Carson Sirens, Feniex and Pimp Pods
    http://www.centexpse.com
    www.facebook.com/centexpse
  11. #11
    Senior Member
    Ipuvaepe is offline
    Joined June 2011
    Quote Originally Posted by CenTexPSE View Post
    Ding Ding my point exactly, and with the power and size of those things I'd say even closer than that. Remember the video of the pumper that had w/w split heads and you couldn't even tell they were emergency lights until someone pointed it out?
  12. #12
    Moderator
    Communications
    Fire/EMT
    Military
    Phoenix_Rising is offline
    Joined February 2012
    Berks County PA
    I never was,never will be a fan a split heads. This is split-fail hands down
    While the wicked stand confounded, call me with the Saints surrounded
    My statements are strictly my own and not of my company/affiliations.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
