Results 1 to 24 of 24
June 18th, 2012, 04:50 AM #1Author of This ThreadVeteran
- Joined May 2010
NY, USA1,943 PostsPower Arc Ambulance
June 18th, 2012, 08:51 AM #2
No split fail or pattern fail on the 9x7 lights +1
Oscillating lights +1
Split flash on the rear center amber -1
The only other thing I would say is that it will be hard to wash. I'm a sucker for oscillating lights and therefore really like this truck... thanks for posting it.
June 18th, 2012, 11:49 AM #3
Oscillating LEDs. A novel idea.
The siren fanatic.
June 19th, 2012, 02:35 AM #4MemberParamedicVolunteer Fire/EMT
- Joined June 2010
Upstate NY181 PostsYuck. It's a novel concept, but the lights really aren't that bright and not very attention getting. An EMS squad I volunteer with has 2 PowerArcs on the back corners of the box. A clear lense with 1/2 oscilating red, and the other 1/2 non-moving amber. The rest of the box has standard Whelen 9x7s. It's a novel idea, but not a very good use of space in my opinion in terms of bang vs. buck.
June 19th, 2012, 08:47 AM #5Member
- Joined May 2010
Blacksburg, VA242 PostsI like it. First time seeing the Powerarcs stationary LEDs - looks good to me. I wonder if the Fed Sign SLR will further eat into PowerArcs market though?
June 19th, 2012, 08:55 AM #6MemberVintage Collector
- Joined June 2012
Kalamazoo, MI238 PostsMy eyes caught on to the oscillating LED's and nothing else mattered!
June 19th, 2012, 10:14 AM #7
June 19th, 2012, 10:21 AM #8
June 19th, 2012, 11:13 AM #9
Lost me with the Sprinter chassis; otherwise,
June 19th, 2012, 11:27 AM #10
Have you ever driven one? I'd take a sprinter hands down over an e series ford any day. Sprinters are fast becoming the only dependable diesel of their size. Besides the fact that the e series is now gas only, the sprinter accelerates, corners, rides better than any other "e" sized truck I have ever driven. I have run EMS out of everything from a non raised roof gas van to an extended cab international, and sprinters are hands down the best all around vehicle. That said, they simply cannot meet the needs of some agencies. If you need anything bigger than a "mini" modular then you should look elsewhere. They are not pretty...
they are like carrying a European man purse....
useful and practical as hell.......
but you still think the cool guys might make fun of you....
June 19th, 2012, 12:23 PM #11
June 19th, 2012, 04:45 PM #12
June 19th, 2012, 05:31 PM #13
Also, looking again, the rear should have 3 whelen 900 series primary lights, not power arcs used in place of them....
June 24th, 2012, 07:01 PM #14VeteranMilitary
- Joined June 2010
California1,856 PostsNever accept a video as proper proof of a warning light's effectiveness. Cameras cannot reproduce images exactly as our eyes see them. This video also wasn't taken at a good angle to show how it actually looks from a driver's perspective; the lights are all too high. If the video was taken from farther away, like 100 feet away or so, it'd be a lot better.
Fewer, slower, bigger. (Usually.) When putting warning lights on a vehicle, ask yourself why exactly you're putting that particular light in that particular location: Why are you using that light? What advantage does it have over other lights? Why that particular location?
If you're doing it because it looks cool, it's probably a bad idea. Unless an AeroTwinsonic is involved, in which case it's automatically both cool and an excellent idea.
June 24th, 2012, 07:04 PM #15VeteranMilitary
- Joined June 2010
California1,856 PostsFewer, slower, bigger. (Usually.) When putting warning lights on a vehicle, ask yourself why exactly you're putting that particular light in that particular location: Why are you using that light? What advantage does it have over other lights? Why that particular location?
June 27th, 2012, 01:01 AM #16Senior MemberVolunteer Fire FighterVolunteer Fire/EMT
- Joined August 2011
Stamford New York USA512 PostsCMT(Cooperstown Medical Transport) has i think 3 of these sprinter vans. however they are not equipped with powerarc lights. nor are they Whelen. i believe i was told they had either code 3 or Federal Signal versions of the 900 series Whelen heads. but regardless. John is right. these Sprinters are becoming more and more popular with the EMS profession. Hobart has 2 1998 E-series vans that are literally 1 number apart on the VIN. they are equipped with strobe/halogen whelen advantedge bars and older model halogen 900 series heads. i have tried to talk them into getting a sprinter but no one wants it. even if its roomier than either of the vans we have.
June 27th, 2012, 05:14 AM #17
The number of deisel options in the "e" size chassis are shrinking fast... Sprinters are really the best all around option now for the van and small mod market.
June 27th, 2012, 09:22 PM #18Senior MemberVolunteer Fire FighterVolunteer Fire/EMT
Stamford New York USA512 Postsboth of our ambulances have the powerstroke diesel engine. so does our mini pumper and our rescue. however our rescue is nutless. could be because of the amount of equipment we have in it. the ambulances are slightly different. 1863 is a little more responsive than 1862, but then again 62 is used a lot more. 1813 is the mini pumper and i have never driven it as i dont know how to drive a stick. so i dont know how it is performance wise. but what i hear from CMT is they love those Sprinters and plan on getting more of them
June 27th, 2012, 10:26 PM #19Senior Member
- Joined May 2010
Levittown, Pa568 PostsThe E-Series will be getting a Diesel motor again very shortly esp after this. http://www.epa.gov/otaq/highway-dies.../420f12025.pdf
June 28th, 2012, 02:58 AM #20
Ford To Phase Out E Series...
August 4th, 2012, 09:10 AM #21MemberFire Fighter
- Joined May 2010
St.Louis , MO179 PostsWe have oscillating power arcs on the front of our fire truck and the stationary power arcs on the side bumpers and slow flash and they are super bright. Power Arc makes a great product and regardless of some here, they do get attention!
August 4th, 2012, 01:53 PM #22
August 4th, 2012, 02:06 PM #23
September 27th, 2012, 10:32 PM #24MemberFire/EMT
- Joined May 2010
Guthrie, OK166 Posts
26Likes
LinkBack URL
About LinkBacks
992 Beacon
994 Beacon
Commander 5200
Commander 5200
Commander 5200
Freeze alarms, deputy and Clear-Ray
Mini Advantedge
Oscillating Commander
Oversized beacons
Sireno 300
Stinger
Strobe Commander
Strobe Commander
Strobe Commander
Whelen 80H-5
Whelen 994
Horton Ambulance
POV Sonata
Whelen PCCS9NP and L32 Beacon
Today, 02:23 AM in For Sale or Trade: Warning Equipment
