Results 1 to 4 of 4
Like Tree3Likes
  • 3 Post By JazzDad
Thread: Video: House fire starts by "Mole Bomb"
  1. #1
    Author of This Thread
    Vintage Collector
    boboloo is offline
    Joined June 2012
    Kalamazoo, MI
    Low water pressure slows down firefight | WOOD TV8
    Home video courtesy Troy Tissue via ReportIt and WOOD TV 8
    It was hot yesterday here in MI and very dry. This homeowner set a mole bomb and sparks started grass on fire, later house.
    Hydrant pressure low because of high use and subdivision main is capped at the end.
  2. #2
    Veteran
    stansdds is online now
    Joined May 2010
    U.S.A., Virginia
    Why do people do this? There are far easier and less dangerous ways to control pests.
    Just because you can do something doesn't necessarily mean that you should do it.
  3. #3
    Veteran
    First Responder
    Volunteer Fire Fighter
    JazzDad is offline
    Joined August 2011
    South Central Texas
    %#*^&@ moles!
  4. #4
    Support Services is offline
    Joined May 2010
    Lebanon PA
    Same here
    This happened here recently. 2 guys trying to get rid of a groundhog that took up house keeping in a tunnel under their family shed. They stuffed a lit road flare in the tunnel, good bye shed. Now I had heard this before and coule not remember where I got it from. Several days ago I was watching vintage TV and Reed on Adam 12 had a gopher problem, Malloy new the answer. Yep stuff the holes with road flares. Reed was lucky.
    Any Mission
    Any Time
    Any Where
    Support Services
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
