whatevah
It's not done yet, but it's serviceable and I can't resist posting a video.
Front-
Feniex Fusion 800 dual color, blue/white. mix of 40* and 180* optics. Custom mount to windshield frame.
Whelen Dual Talon, blue.
Feniex Fusion surface mounts dual color, blue/white. 180* optics.
Wig-wag- offroad flood lights recessed in bumper (not yet hooked up)
Sides-
Fusion Fusion 200 single color, blue. 180* optics. Window bracket.
Rear-
Feniex Fusion 800 dual color, red-blue/amber. 40* optics. Mounted to window hinges.
Feniex Cannon 120s dual color, red/white and blue/white. Will be mounted in reverse light housings.
Feniex Fusion surface mounts dual color, red/white and blue/white. 180* optics (on bumper)
Feniex Fusion surface mounts single color, red and blue. 40* optics. Will be mounted to inside of hardtop behind the window for when the window is open and 800 stick is pointed at the sky.
Controlled by Feniex 4200 with bluetooth module. Switch panel is on an overhead rack. Bluetooth is behind the passenger rollbar cover to give it better range. 4200 base is with a Storm Pro 100W siren inside the rear floor cubby.
Also have a pair of amber/white lights that I intended to mount in recessed positions on the back bumper, but I'll have to take off the bumper to reach the mounting bolts. There's a pair of offroad LED lights mounted on top of brake lights, these will be turned out for alley lights... originally used for offroad reverse lights and work lights when camping.
Front-
Sides-
Rear-
