billyfromhill
I have a 2014 Police Interceptor Utility and I want to mount two lightheads in the rear window and several round illumination heads in the tailgate that will be controlled by a switch on the hatch. What is the best way to run power wires from the front console area to the rear hatch/cargo area? Can they be run up the A-pillars and through the headliner or is there a better way to run them? The 2014 upfitters guide is not terribly helpful. I'm also planning to install two NMO mounts in the roof. Should the coax go down the A-pillars and under the dash to the console or should they be run down the D-pillars and through the door sills? My vehicle does not have the rear console plate or the Ford cargo wiring upfit package (67G). You can see the photo below for all of the options my vehicle came with if that helps at all.
