2016 RAM 1500 Speaker Mounting w/Active Grille Shutters
BAKE19
79
Philadelphia, Pa.
I've searched here and seen many people post about grille lights with the active grille shutters. I have found a couple ways to possibly mount my Whelen IONs behind the grille. However, I cannot come up with a good way to mount my 2 Whelen speakers. Does anyone have any experience with these trucks? I would like to avoid mounting the speakers behind the bumper, and the bull bars look out of place to me on these trucks otherwise I would go that route. Any help would be much appreciated!!
CanamRider
32
LA
I did an install and we mounted both speakers up under the bumper and mounted M4s in the grill (outside the grille should I say).
jswwjw
601
Southern Indiana
I had a 2015 Dodge Ram. When I mounted the One Whelen speaker I did it on the drivers side; but took the mount and reversed it and only used the top 2 screw connections (I did use lock tight on them) which then put the speaker low enough to hit the center of the grill. As far as the shutter grill; I gave up on trying to install them at different heights because the make up of the grill really did not allow them to come through. I ended up putting vertex's in the chrome grill with the chrome bezels and it worked good and provided additional coverage.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
im having the same issue with my 2016 f150 it also has the active grill shutter thing and i need to mount 2 speakers.... dono yet what ill do
we through mounted some bolts on the frame by the front wheels.
ErikH
