4200DL and Storm Pro 200w
Doyle257
658
Cheektowaga, NY
OK, so the instruction manuals online are not very clear as to how the DL option works.
When using the RJ45 cable between the Storm pro, and the "Brain" of the 4200, is it necessary to still run individual leads to each used siren tone input, and an output on the 4200??
If so, what is the purpose of the DL??
buddek09
339
US, Ohio
No it's not necessary to run individual cables. The only thing you will need to run still is the power wires. In the 4200DL program you will see a box on the right side labeled as siren. If you don't see this box then you have the wrong program version. This is where you will set the siren tones. Simply select the button or slide switch you want and set the tone for each speaker.
Reactions: Doyle257
Sanman
