700, 710, 711 flasher differences and question.
Minnesota
What is the difference in patterns?
I replaced the failed control board in a Jetsonic with a 711 to give me 2 flash patterns and steady rotate. pattern one will alternate 6 flashes then simultaneous 6 flashes. Mode 2 is simultaneous. Steady will activate the rotators.
I would like mode 1 to alternate only and mode 2 simultaneous only.
In watching some youtube videos I dont see one with an alternating pattern.
so what is the difference between the 700, 710 and 711 flashers?
Elmira, ny
700 does a basic wigwag pattern
711 does a double wigwag 2 times drivers side 2 times passenger side (if i remember right)
711 does a double pattern 6 times (2 3 double flashes each light) and then a simultaneous triple pop for each lighthead.
Hope that helps. The steady burn override if i remember right is for to make flashing takedowns go steady.
Im sure someone else knows more, i've had all 3, but so far i like the 700 bestest
Minnesota
Thanks. That goes along with what I have seen so my memory must be off.
I thought I had a 700 series that mode 1 was only alternate (like the 700) but also had mode 2 as simultaneous flash as well as a steady. Guess I have been chasing my tail for years on that one.
The steady on worked as a high beam override too as an older headlight flasher.
700
710
711
mode 2 for 10 and 11
ErikH
