Application Question
billforbush
313
Northern Michigan
I've been through the application guide and can't seem to locate the info I need. Could you please help me? I need the model number including shaft length and mounting kits LH and RH for a 2015 Chevy Silverado 2500HD pickup. Black 6" halogen. Cheapest bulb as I will swap out with 100w glass sealed beam on arrival. I know I'll have to replace the OEM pillar post trim to eliminate the handles. Thank you very much
UnityUSA
121
Chicago IL
2015 Chevrolet Silverado:
Driver Side (LH): 213010-0002 spotlight mounted with 263 installation kit. Shaft is 213000 series LH custom fit shaft. Replacement shaft 3615-GM-105
Passenger Side (RH) 213011-0002 spotlight mounted with 263RH installation kit. Shaft is 213000 series RH custom fit shaft. Replacement shaft 3615-GM-107
Reactions: 801
UnityUSA
121
Chicago IL
You're welcome. Let us know if you need anything else.
ArizonaFireTruckParty
