Arrow 531 Vs. 551 beacon... anyone?
894
1,036
North Central US
I recently acquired an Arrow 551 4 sealed-beam beacon and immediately noted the orientation of the sealed beams to be "non-horizontal" (two 15-degree upward, two 15-degree downward). None of the 4, level w/ the horizon. I did some research to determine the beacon's origins and an old Oshkosh truck w/ a snowblower affixed got mentioned as a possible source... the previous owner was just cleaning-out the "back room", if you will... maybe an airport application?
I guess to verify its legitimacy, who has some old "Arrow" literature to verify the model # designations and/or has anyone seen another like this? I can't say I have. I've had a few 531's roll across my workbench over the years but the 551 doesn't ring any bells... Neat old light, nonetheless!
What say the masses?
Mars Light
1,500
Leipzig, Germany
The 531 is a standard 4-sealed beacon.
In some case the top fixing cross was rotated by 90 degrees. This caused a hill-light look a like but its not original.
cmb56
746
Norrköping, Sweden
To what I can recall there was a name change when Arrow changed to cheaper motors.
530 become 550 and 531 become 551.
530/550 = 2 sealed beams (7400)
531/551 = 4 sealed beams (7400)
Michael
894
1,036
North Central US
I never opened it up but I can see what you're describing. Makes perfect sense. Someone had it apart once upon a time and didn't pay attention to what they were doing! I'll have to make a correction. I had never seen the 551 model # so I thought maybe it was a unique designation. Simple fix!
kerry4951
825
Central Pa
I had the same thing awhile back. Thought I had a real rare one. Then I realized someone never installed the top bracket properly causing the bulbs to tilt.
Reactions: 894 and dmathieu
Caldwell205
