Lets assume we have a one-channel strobe. It has two lamps (in parallel). If one lamp burns out, does this typically cause the other lamp to more quickly fail?
Situation: I have a two-channel, 4 lamp circuit and all 4 lamps test to be bad. It just seems odd for all 4 to have failed.
(The trigger connection is obvious, and I swapped the anode and cathode just in case I hooked them up in reverse. Using a known good 9M4S supply.)
