Can you make a left hand spotlight to right hand
NCAP126
202
New York
Have a NIB Unity 94018-0002 LH LED spotlight. Wanted to know if I can use this as a 94019-0002 RH. If so would I just need the right hand install kit 5557 for a Ford Crown Vic or also the right hand plate kit package. Thank you.
UnityUSA
121
Chicago IL
They are not interchangeable. The shaft of the spotlights on the two sides are different. The light would not function correctly on the passenger side. The shaft can be changed out to switch sides. Replacement shaft for passenger side is 3615-GM-65. You would need 5557 installation kit to mount the light and 3746-R retainer plate.
3615-GM-65
http://www.unityusa.com/3615-GM-65-Shaft-Headpost-Assembly--RH_p_700.html
5557
http://www.unityusa.com/5557-Installation-Kit_p_809.html
3746-R
http://www.unityusa.com/Retainer-Plate-Kit-Right-3-holes_p_2137.html
NCAP126
202
New York
Ok thanks. A follow up to this is how do you tell the difference between the 2 as I see no markings on the shaft? If someone is selling a used RH how would I know it actually is? Thanks again.
ErikH
