Carson SC-550
NReck
8
Wisconsin
i just installed a Carson SC-550 in my truck. On the slide switch I have 1 powering an external feniex flashed powering my rear warning light and on 2 I have it powering a Whalen flasher powering my fronts. When I have the siren switch turned to horn/standby and I have the switch on 1 or 2 I hear a clicking coming from the speaker. The clicking follows the flash patterns. It's a quite click you can only hear it standing in front of the speaker. I have tried switching the wires of the speaker around I tried another speaker and it does the same thing. With the siren on you can't hear any clicking. Any ideas on what I can do to stop the clicking or is this normal?
Check your grounds.
Then there's your problem.... all grounds need to be as short as posdible
Reactions: Tony P
It's your other grounds you need to fix....
NReck
8
Wisconsin
I made a new ground for the entire bus bar. And an entirely separate ground just for the siren. The ground cable is less than a foot.
I think your missing my point.... all grounds need to be kept as short as possible. What do you have run to this ground bar? Hopefully not the individual lightheads?
NReck
8
Wisconsin
No I get the point all the grounds are short in length. The only things that are grounded to the bus bar now are 2 relays and the Whalen flasher and the feniex flasher. Then a different ground for the siren itself.
Ok so now what do you have the bus bar grounded too?
NReck
8
Wisconsin
The bus bar is grounded to a seat mount. The ground is good tested it with a volt meter. There is a 8 gauge cable that is 4 in long that goes from the seat bolt to the bus bar. The wires from the bus bar to the relays and flashers are 4 to 8in. The ground wires from the siren to a chassis ground are 2x 10 gauge wires that are 11in long.
Relocate buss bar ground to chassis ground if possible. Did you scuff the paint at the seat bolt?
NReck
8
Wisconsin
Paint is removed to bare metal and used a star washer to help dig into the metal. It is a solid ground. I could move it but would lengthen the wire to about 16in instead of 4in. I have tried multiple combinations of setting up the ground cables.
Ok so how is power ran to siren?
MtnMan
1,533
Eastern PA
I've experienced other Carson sirens with low-level audio feedthrough (e.g., the radio input is faintly audible through the speaker when the siren is in standby mode), and I suspect it's a design characteristic.
You could isolate the flasher with a relay, or try a different flasher altogether, or just don't worry about it.
