Sorry Mike, I don't always check this site on the weekends. I don't think it will work just hooking it directly into the Sapphire. As discussed I think you need to use a relay. I think your programming is correct but as pointed out above the voltage isn't enough to trigger it. The upfitter's guide states "the door ajar circuit is used to supply a module that has pull up resistors in it's inputs". Basically means they intend for you to use a device that converts the 10v signal to the full 12v. I tried searching for the module, which they don't have any parts number reference to, and could not find anyone that makes a module. Probably some Ford proprietary module. Basically you would have to design and build your own, though not hard, it's easier to just use a relay. For the relay pin86 to the door ajar signal wire, pin 85 to ground, pin 30 to input 1, and pin 87 to a 12v input or you could just tie it to ground and change the setting for the input to ground. Wiring the relay up this way should make it work exactly how you want it.
