Straypuft
Just got the title mentioned bars this afternoon from a craigslist find.
Im told the bundle of cables used to connect to a controller is a wire harness, Is it called a harness just because its a group of cables? or is that a part that connects the wires to the mainboard?
The manual for the Vector SL lists different types of cables and only 1 group of cables comes out of the bottom, Dont know if I need both a control cable and Ground cable.
The cable in mine is cut down to about an inch outside the bottom of the bar so I need a replacement, Where might I be able to find a proper or compatible replacement.
I cannot find a parts list for the Mini Vector SL so the same question applies, Where to find a cable for it as well. Not looking to spend a lot of money and for the time being, these 2 bars will not go onto a car, just for display only.
