tbrown
We just got a used Fusion Rear Inner Bar (being used as a front bar) and it has takedowns on each side, however when you supply +12v to the white lead, the two center lights become solid. Is there any way to reprogram the bar so the takedowns actually turn solid when the white wire is connected rather than the reds? Essentially the white lead is making the 2 center reds become steady burn turning the bar into a CA Title 13 legal bar rather than activating the actual takedown lights. The wires from the LEDs are not long enough to plug the actual takedowns into the spots on the controller the center reds are currently occupying.
Is there a way to reprogram which lights are the takedowns or do I need to splice into and elongate the wires to swap where they plug into the controller? I don't see anything about this in the install manual.
The bar is setup as:
R R TD R R R R TD R R
The center 2 reds are solid when you connect the white wire but I would like the actual TD lights to be solid when this happens.
