Hand-held controller?
ShadesBorg
2
Atlanta, GA
Hi,
I'm working on putting together an install right now and I think I've got everything figured out except the controller/switches for the lights. I'm ideally looking for something hand-held, like this:
Yes, I know its a massage chair remote, but its the best example I could find as far as the physical form factor I'm after.... Does any such device exist? Thus far the closest thing I've been able to come up with is this:
http://www.911signalusa.com/911-990-switch-p-94.html
Ideally I'm looking for something with at least 6 buttons; half of the buttons will be used for on/off functionality while the other half will be for changing flash patterns.
If it makes any difference, here is a list of the actual lights I'll be using:
10x LAMPHUS SnakeEye II-6W SEHA16 REV.1 6W LED Hideaway Strobe Warning Light
2x LAMPHUS CosmicRay CRLH06 6W LED Linear Strobe Warning Light Head
I'm pretty new to this type of thing so if I've overlooked something please feel free to let me know; any & all feedback is certainly appreciated!
Thanks!
mdlighting
648
PG county,MD
Whelen HHS2200 is the best Hand Held Siren out there a little pricey but well worth it 200 watt siren with tons of diffrent tones to choose from and fully programmable.
ShadesBorg
2
Atlanta, GA
Hi,
Thanks for the quick response; I actually don't need any type of siren functionality; the vehicle will have lighting only... With that said, could all of the buttons be easily programmed to control lighting or are some of the buttons "hard-coded" for siren functionality only?
Thanks!
mdlighting
648
PG county,MD
Yes just remove all of the siren functions in the programing and you would have 12 buttons to play with. The HHS has 8 15amp outputs to choose from so you could have all of your lights on their own output and have a few buttons turn on different combos for diffrent scenarios
Station 3
Edinburg Texas
LCS869 remote siren is awesome and it has like over 10 siren tones you can use even mechanical tone.
cameronbraedyn
