Havis Faceplates and Jotto Desk Console?
jluisi86
125
Poconos, PA
I am using a Jotto Desk and found a faceplate that Havis makes. Do Havis Faceplates work in a Jotto Desk console? If so, do they look the same with the same texture paint? Thanks
Columbus, Ohio
Face plates from Havis, Jotto, and Troy should all work with each others consoles. Finish is not going to be the same at all. Every manufacturer makes their stuff a little different. I personally like the Troy brackets the best, they are usually a little more heavy duty but you do pay for that.
C2Installs
477
Tennessee
Width and length are compatible between JD & HS. Problem will be that JD uses fixed screw holes on its mounting lip and HS uses a track with no fixed positions for mounting. So, you may have trouble mating faceplate screw holes to screw holes when putting HS plates on a JD console, but not the other way around. Worst case, you might need to drill new holes in the console mounting lip. Finish is similar, but smoother and glossier on HS plates. JD is slightly more textured.
ErikH
