Havis PKG-DS-APP-112 Apple I-Pad 12 Volt Mount + DS-DA-702 Protective Case
Rgonsior
145
Minnesota
Brand New in the box, will fit I-Pad 4 with the lighting connector.  Comes with 12 volt powered mount and protective case.
Product Details:
  • Docking station and protective case package for iPad 4
  • LED power indicator light
  • Low profile design maximizes available space inside of vehicle
  • Rounded corners and edges are ideal for your safety in accidents and airbag deployment, in addition to daily use and operation of docking station
  • Designed to fit all VESA 75 hole pattern mounting equipment
  • Lock and key supplied for peace of mind theft deterrence
  • Cigarette lighter adaptor power cable included
Specifications:
  • Compatible computer: apple iPad 4 tablet
  • Docking station connectivity includes: power input: 12V dc
  • Certifications: Vibration Testing, Crash Testing, Thermal Testing
  • Docking station dimensions: 10.8" (27.5 cm) x 6.9" (17.6 cm) x 3.12" (8.0 cm)
  • Docking station weight: 1.6 lbs. (0.68 kg)
  • Protective case dimensions: 11.4" (28.9 cm) x 8.7" (22.1 cm) x 0.87" (2.2 cm)
  • Protective case weight: 0.8 lbs. (0.36 kg)
  • Shipping Weight: 10.00 lbs
$199 With Free Shipping!
Nathan R
Mar 27, 2014
853
USA
Your thread has been located to the proper section. Please double check where you are posting before submitting. A tablet mount is not Warning Equipment.
Thank you.
Advancedstreet
