emtmike said:made by sp, markx or mark 10, youtube it, same company made mark VI VII, i believe they were called scientific prototypes
WS224 said:I think I have some pin out info on the Mark VII's. My guess would be that the harness would be the same. Let me see what I can dig up.
Black Hoe said:SP sirens were primarily used in New York City by the PD and EMS back in the 70's into the early 80's. I believe that some of the Signal Stat sirens of that era were actually manufactured by SP.
dcsru said:Great, thanks! It doesn't have the harness on the back so it looks like I will have to put something together
WS224 said:While we are on the subject, I have a Mark VII, but it is not the NYPD version. The siren button operates like a standard tap two or 5 second yelp button. It does not instant on or off. Anyone know how to convert it?
CHIEFOPS said:.......The Stat 10/MARK 10 was simply a combination siren and switch unit that I don't recall was ever used in precinct RMPs but was possibly used in ESU REPS......
Hi gang and thanks for all the information. I notice there are two slide switches inside on the circuit board. One I would imagine is for the 50 watt / 100 watt out put. Any idea what the other small slide switch is ???
There are three slide switches on the Mark VII PC board:
Switch at the rear of the board is 58/100 W.
Switch at the front left (directly behind the function selector) is a three-position slide that disables either the wail or hi-lo tones. Center is normal operation.
Switch at the font right is horn ring polarity.
