My 2010 F-150 4x4 Patrol Truck
Station 3
Edinburg Texas
This patrol truck was a slick top unmarked unit before I got it had no cage no roof top lightbar just interior lights. I had a legacy installed and a cage and had the interior rear bar removed out of fear of a prisoner using it as a weapon and had no real other option but maybe the tool box but it would hit the rear window when lifted. I decided to install it on the rear tailgate never seen it before and I think it came out pretty good and give off a huge amount of light. What do you guys think.
Also for the whelen fan boys try to spot all the burned out whelen lightheads..... I will give you a hint its around 9 light heads..
Reactions: dmathieu
coopers
271
WA
Interesting spot for the dominator but looks like it works. You run sapphire or carbide? You like the truck over a tahoe or PIU?
Station 3
Edinburg Texas
I run a hand held whelen siren. Not my choice but it will change soon to maybe a cencom gold or something old with more buttons.
Kendreth
141
Nashua, NH
i like that location never seen it done before, seems to be a good fit. is it wired completely into the tailgate so it can be operated normally?
TJW
107
MB, Canada
Going left to right are modules 2,3,4,5,6, split in the dominator or are they partially burnt out? Could very well be my decreasing vision or the video capture but it appears that 5 of them ( three red, two blue) are decreased.
Truck looks good by the way.
Reactions: Station 3
#1texan
271
Texas
Also one on the passenger side running board (I believe the middle red one)
kitsune86
152
Texas
As a Whelen FanBoy(tm), LINZ6's are the WORST for half-burning out.
I managed to get my shop to switch away from LINZ6's to Ions about a year ago and have not had any problems like the LINZ6's did.
Good lucking truck, interesting idea with the Dominator on the tailgate like that.
Station 3
Edinburg Texas
A
About 5 heads in the dominator are burnt out half way also one vertex hide away in the tail lamp is burnt half way 2 side lin6 running board lights are also burnt and a few in the front interior bar turn on and off when they want to..
JazzDad
5,165
USA
Just curious, if you are off duty from the Constable's dept, can you respond to a fire call in that truck?
Reactions: Doyle257
ArizonaFireTruckParty
