PTRJason
This is my issued unit. I added steady burns to the lightbar and put them on position two
Position 1: Rear corners of Liberty, traffic advisor, rear Whelen LEDs in back window, and Whelen HAW LEDs in reverse lamps
Position 2: same as one with steady burn red and blues to the front
Position 3: full bar with flashing TD and AL, HAW LEDs in headlights, HLF, Setina push bumper with Whelen LINZ6 built into front bar and also mounted on sides, and Whelen TIR3s mounted in the grill.
I also added a Motorola ML900 to it with a Gamber Johnson dock and floor kit for an Explorer. Added a Sirius XM radio and Dock. And added a shotgun rack to the top of the partition since none were ever put it and my shotty and long gun were in a case in the back of the SUV.
I just ordered an AR mount so I plan on trying to out that between the seats if I can without moving the video system DVR that is there.
All the lights and everything were already on it. I just added the steady burn to the bar and made it so they come on in position two.
It is a Code-3 Mastercom and they had it so that the built in park kill killed position 3 when in park. So it was hooked up so position two was everything except white light. Three was white light. When in three and you hit park, it reverts back to position two, which is all but no HLF, TD or AL.
I also added a SoundOff dome light.
