Phoenix_Rising
Pair of Whelen DUO Blue/Amber LIN12 500 series heads
do NOT purchase via Panjo; direct sale only. Purchases through Panjo will be returned
Up for sale is one pair ( 2 led light heads) of Whelen DUO heads , model LIN12BA. These are true duo heads. Please note the following: there is an epoxy around the head where lens would mount to the head. Helps seal head when mounting lens should one opt to use externally. The amp/ quick connect plugs have been removed: please note wire length as shown in pictures. Both sport 2/12 date of manufacture. These are dumb heads/steady burn. You will need a flasher to make them flash (not included). Also note that if you purchase these, you CANNOT run both colora at the exact same time. You can alternate the colors , however burning both colors in sync with eachother you will burn the boards.
Item are tested and working however sold as is where is, with no returns. Items are shipped USPS flat rate priority with tracking info. Payment by paypal only (no e-checks). By buying my item you agree to the terms listed herein.
Price is $100 shipped for the pair OBRO
List Date: 5/5/2017
For more info, click here to view the original listing: Pair of Whelen DUO Blue/Amber LIN12 500 series heads
This item is no longer available.
List Date: 5/5/2017
aimagecdn2.panjo.com_images_threadpost_d52eaff6_e370_42b3_b677_747871c70858.JPG67.3 KB · Views: 13
aimagecdn2.panjo.com_images_threadpost_687e784d_9f18_4690_a81c_5acd735759b0.JPG59.5 KB · Views: 13
